Jerky Diesel?
'13 3008 1.6 HDi GripControl - x 996
My Xantia TD used to do that - get it below about 1500 rpm on overrun and it would jerk away - solution was to change down to get the revs up. Never found out why it did it, but it never changed in the 40k I had it - including after I changed the cambelt, which did make the engine smoother and pull better from low revs.
Not much help I'm afraid, but I just lived with it.
I've had 3 PSA diesel engined cars - first one has 240k on it (Pug 205d - sold to a friend) and it's never had anything done to the injectors second was a bx 1.9d -200k+ on it with no injector work. current one is a zx 1.9d 126k and ditto.
I've had an injector stick before, but nothing that couldn't be sorted out by a bottle of injector cleaner and a good thrash up the motorway...
Ron
Ron
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by oilyspanner</i>
The bottom engine mount causes these symptoms when worn, it first shows up in traffic jams as the heat softens the rubber. need to change mine.
Stewart
Hmmm, this sounds very much like my current irritation. Feels like the clutch is juddering, hardly anything when cold, gets much worse when hot. I was beginning to think new clutch but this has given me some hope. <fingers crossed>
Stewart
My first BX TD didn't do this, and the bottom mount on that was soaked in oil, and squishy as anything - the ZX TD doesn't do it either, and the mount on that looks pretty ropey too. By comparison the mount on the Xantia was dry and looked v.good. The Xantia did have that stupid thing on the accelerator to damp the last little bit of throttle movement - I always wondered if it was something to do with this, but never got around to taking it off to see.... The Xantia was also difficult to start hot - requiring glow plugs even after just a minute or two stopped - this may have been down to an air leak that only developed when it was warm, which may also have affected the running.
I had a similar problem with a Pug 205. Top engine mount was broken. Replaced it and found the o/s driveshaft intermediate joint was worn also. "Surely if it was running properly it wouldn't be doing this? " It will if you lift your foot off the throttle and slam it back down again. You are testing the braking of the engine. Mountings will be put to the test too.
