Hi all,
Posted last week about the rear hub on the Xantia now making an annoying noise after having been picked up as an advisory at an MOT as 'rough in operation'.
Now, the parents are taking the Xantia on a 150 mile trip tommorrow and I'm a tad concerned about this dodgy hub - you can only really hear the noise with the seats down but all the same I'd be interested to know what happens to these as they get worse - if its something like the wheel falling off then I'll be lending them my Mondeo!
Cheers.
Xantia rear hub faliure?
AndersDK
The rear Xantia hub is the same construction as the rear BX hub.
I've been driving for approx 1/2 year with a bad rear wheel hub in one of my BX'es. The only consequence was a (very) annoying noise.
When I finally got to replace the hub, there only some play in the bearings. Nothing like the scaring scenareos.
If the problem is ignored it will at some point get dangerous of course. But that would take at lest some 5000miles. And long before it comes to that - you will get other rather annoying symptoms - like a woobly rear wheel influencing badly on the steering.
And the noise seems to increase, so you never forget ...
nick
Kowalski
My mother had a Volkswagen Jetta that had a noisy rear wheel bearing. They were tapered roller bearings, solution was to take the bearing races out, clean them regrease them and put them back together, this was done a couple of times and each time it quietened them for about a year before the noise came back.
Eventually, the wheel bearing was replaced they didn't need any annual regreasing after that.
