Autobox problems
Justahooligan
Autobox problems
I have just bought a V6 Espace Auto, but found it to have a problem when at between 25-40 mph, it appears to be indecisive about whether or not it needs to be in 2nd or 3rd. I rang the vendor who tells me that the box ecu was recently replaced. Is it possible that I have the wrong ecu? Can I reprogram the ecu or do I have to find the correct ecu. The engine number is F019952 and vin number vf8j638450R442168. Any clues most gratefully received.
Justahooligan
Stuart McB
Justahooligan
dan.2cv
I'm really interested to find out exactly how you sorted this out, as I had a 2.o laguna which did exactly the same thing you describe. I took it to a mate who plugged it in to the renault xr25 which showed no problems, so my ar*e went and I sold it (disclosing the problem) on e-bay.
I would be as sick as a pig to think I could have easily fixed it!!
Justahooligan
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dan.2cv</i>
The guy I spoke to was brilliant. I explained the symptoms, he asked a couple of questions then came up with a probable solution. He then gave me the part number of the suspect part, explained how to change it and offered further assistance if this didnt cure it. £9.68 later, fixed.
Stuart McB
Justahooligan
dan.2cv
Justahooligan
Stuart McB
