Stuart...
How did you fettle the BX wiper to park on the opposite side.[?][?][?]
Fancy doing this modification to the AX - had a look @ the wiper assembly and the Haynes BOL, but nothings leaping out at me...
Cheers, Marty.
One for Oilyspanner...
oilyspanner
martyhopkirk
Thanks Stewart - will have a good look and see if I am man enough for the job!!!
New AX surprisingly good so far - only the handling into corners gives cause for concern - lots of body roll, so not sure if stiffer shocks or a strut brace is in order - shocks seem ok, good ride other wise. (Not a patch on ZX or Xantia when thrown into a roundabout with gusto!)
Timing belt gets done this weekend - and coolant if possible (not a lot of heat from matrix, so will flush) Then will be pressed into daily service and hope someone will part with about £400 for a ZX with tax and MOT till end of August.
oilyspanner
mbunting
martyhopkirk
