Activa leaking LHM...
macaroni
being quite new to Citroen ownership, please bear with me...
My STOP light came on my Xantia Activa this lunchtime and a quick inspection of the reservoir confirmed my worst fears - empty. I drove (naughty I know...) round to the Cit dealer to check some LHM and noticed it was leaking from behind the nearside front wheel.
Anybody got any idea what might be leaking? This will give me a headstart when I investigate it tonight.
Cheers,
Antony
Cheers,
Antony
- x 1431
If it's right on the back of the wheel it will probably be the front strut leak off pipes - there should be two rubber pipes looping from the bottom of the strut to the body. Cheal to buy, but a bit of a git to fit because of the clip....
However, this is an Activa, so it could be coming out anywhere!
macaroni
bxbodger
Panjandrum
Depends on how much "leaking" means.
If seriously haemorrhaging it could be a split in the flexible hose(s). Not a cheap fix - I got mine done earlier this year.
PJ
PS - If that's the problem it will get worse, fast, and you will rapidly loose steering, suspension and brakes - just like I did - but fortunately mine happened in the driveway. PJ
PJ
macaroni
Well I have had a quick look and it appears to be leaking from the inner most flex-hose leading to the Activa Ram. Possibly!
It is where the flex-hose screws into the base of the ram. It is leaking quite quickly and I suspect it will fill container overnight.
It doesn't look like a big job if the unions come undone easily.
Does this sound sensible or am I barking up the wrong strut?
RichG
Panjandrum
Antony,
Can you see the leaky hose behind the wheel - meaning is it one of the hoses in the wheel arch? There are two - Citroen price about £25+VAT each. I didn't think the hose to ram was flexible - but could be wrong. Too dark and cold to check just now!! Just sailed through MoT tonight - chuckle.
Be VERY careful. Once that Niagara begins it is no time until you have lost all hydraulic services which is really bad news.
PJ
PJ
macaroni
PJ,
It is a leaky hose behind the wheel. There are 2 hoses that go from a junction quite high up under the wheel arch to the bottom of what I believe is the Activa Ram, could be wrong though. One of the unions at the end of these hoses sits flush, but the one that leaks appears to sit a bit proud, but is definitely tight. I am going to pop into my friendly local Cit dealer today and try to identify what it is.
Thanks for your help.
Antony
Antony
macaroni
OK, just been to the Cit dealer and it looks like it is one of the 2 flexi-hoses going to the Activa ram. PJ was right in that they are £24.50+VAT each, but it looks like a right nasty job to do. The Cit tech I spoke to claims they remove the ram to facilitate the screwing of the union into the ram base.
Not sure I am up to removing an ACtiva ram as they are separate from teh rest of the hydraulic system and require quite complex depressurisation, as far as I understand. Might get it booked in...
Panjandrum
jeremy
I seem to remember a thread on the subject of return hoses from these special Avtiva rams before and the problem there was that having replaced the hoze it still leaked.
I may be barking up the wrong tree but it all sounds a bit like BX front struts. Yes you can get return hoses but if the existing ones are leaking the chances are the strut has gone as they shouldn't leak that much in the first place.
So the question is how good are these struts?
jeremy
jeremy
macaroni
Panjandrum
Just been out to look. For the benefit of non-Activa readers, these are two industrial-strength flexihoses that feed the ram - one for up, one for down. My ram is a bit oozy at the bottom, but not seriously leaking.
I fear that if the leak comes from around the junction itself then you may have a ram defect.
PJ
PJ
macaroni
