Xantia Estate Remote wont unlock boot!
julianashcroft
Unread post by julianashcroft »
The lock on the boot door on my 2000 Xantia Estate has been a bit interminant for a while now. While all the other doors would lock or unlock on a press of the key fob remote, the rear door would take maybe a couple presses or more to lock / unlock.
Today however it wouldn't unlock and my poor old Boxer dog had to clamber over the back seats to get out. I can see no way of opening the door from inside the car and as my remote no longer unlocks it I don't really know what to do.
Any suggestions most welcome.
Ash
AndersDK
Unread post by AndersDK »
No easy solution to that I'm afraid.
Try get your local mechanic to look at it. It's not a dedicated Citroen problem, but a rather common problem to all car makes.
The boot door may have to be stripped down from inside to access the lock mechanism to open the door. And then the fault must be corrected.
CBR600FV
Unread post by CBR600FV »
Had a similar problem on my Xsara estate recently. Try a search under "Xsara Tailgate" for the full story.
julianashcroft
Thanks for the replies. The tailgate opened this morning on the third button press. I will do some investiagting at the weekend. Hopefully I will still be able to open it then.
ghostrider
Unread post by ghostrider »
Mine's the same but using the key seems to work better than the fob
Pete
________
Mexican cooking
James.UK
Unread post by James.UK »
My boot has never opened with the remote (ZX).. it only opens with the key.. but then my elec windows will work with the ignition off if the door is open? handy if you forget to close them though lol.. Its a citroen for gawds sake! no two are the same!... lol
