Before curiosity completely overcomes me and I start taking it apart, can anyone tell me what is running under the right hand front wing? It sounds like a motor running or fan when the ignition switch is on.
I don't thimk it's a diesel water heater but ........ it is a VSX so anything could be I guess. R
What is under an XM right hand wing?
davethewheel
tomsheppard
Robin
NiSk
I have an Ebersprächer diesel heater fitted to my XM 2.5TD. In my case, the heater is fitted into the left hand front wing (seen from drivers seat). There is an extra exhaust pipe poking down through the plastic sheilding under the wing and a whole bunch of extra fuses just behind the LH headlight. there is also a thin fuel line tapped into the main fuel line just after the fuel filter (after about 6").
The space below the RH wing is occupied by a water tank and HP pump for the headlamp washers.
//NiSk
//NiSk
Robin
NiSk, no headlamp washer on mine but I will go back and check out the heater option again. It does at this stage sound like the most likely answer. This is under the right hand wing when veiwed from drivers seat.
If it is then I need to find out how it is controlled, I guess automatically from the climate control centre. there is no mention of it in the handbook. Regards, R
noz
Robin,
You don't say which model you have but if it's the diesel then the noise coming from the offside (RHD) front wing is a vacuum pump. It's sole purpose in life is to produce vacuum which in turn activates the EGR (Exhaust Gas Recirculation) valve.
If ever there was a difficult way to do something.........
I've disconnected mine electrically because the noise got on my nerves.
cheers
norrie
cheers
norrie
Robin
NiSk
Prise out the roof lamp fitting, unscrew the two philips screws, lower the unit, turn the fan unit a 1/4 turn (bayonnet). lift out, blow out all the dust and fluff. If it's still noisy, drop one drop of sewing machine oil on the shaft so that it runs into the bearing (DON'T USE WD40, CRC 556 or similar!!). That should shut it up!
//NiSk
//NiSk
Robin
