key pad code for partner van
moz
Unread post by moz »
what is the procedeior for the key pad code and how doe i use it sorry about the spelling moz
PowerLee
Unread post by PowerLee »
Hi
Turn ignition on, Red LED is on
Enter the 4 digit code & Green LED comes on.
Start the engine.
To change the code you enter the old 4 digit code & then press "C"
Enter a new 4 digit different code & press "C" again
4 beeps & 4 flashes from the Green LED means the code is changed.
All you need to do is to remember to use the new code next time you start the engine to erase the old code from the memory.
moz
powerlee hi and thanks for the info but ihave not got the four digit code to punch in to start with moz
PowerLee
Hi
Try the factory default code ( They where all set to this when the left the factory ) of 1 1 1 1 first & if not your a bit stuck im afraid.
Have you asked the previous owner what the code is?
The code could be anything, If you have the old code you can change it to whatever you like.
You only get 3 attempts at the code before the keypad will lock you out for 30 minutes.
If you get locked out just leave the ignition on for 30 minutes until the beeping & Red LED stop flashing & then you have 3 more goes.
moz
is there any way i can get the key pad code for partner diesel van help????
PowerLee
The code could be any combination of 4 numbers mate, Guessing it will take weeks & risks locking it up compleatly.
You either need to get in touch with the previous owner & ask them or find someone with the correct software to unlock it for you.
A Peugeot / Citroen dealer would have the correct equipment.
If you can get at the diesel pump stop solinoid you can bypass it there ( Good luck with that, Its really well protected! )
There are ways of unlocking the keypad yourself, Ive tried them all myself but they never work for me.
Or you could give these people a try
http://www.unimark.freeserve.co.uk/index.htm
