i checked today and the end injector cap has cracked and now the car keeps cutting out and is hard to start
where can i get this from or what can i do as a temp fix
need help asap
306 TD injector pipe
beezer
If you mean the blanking cap on the leak off pipe I made a temporary fix by cutting the outer sheath off some rubber coated cable (it was mike cable but any similar would do) and placed a bit of rubber glove over the end of the leak off pipe and stuck the sheath over the top. You should get a replacement from a diesel injector specialist or a branch of LSUK (www.lsuk.co.uk).
caveman_si
If it is the leak off pipe from the injectors (and it sounds like it) if one is cracked chances are they all are and ALL need replacing.
Good news is any decent motor factors should have some in just ask for injector leak of pipe. I got about 1 to 1.25 metres of the stuff plus blanking cap about 4months for £1.80 ish i think possible even less. which is well more then you need.
b21playa
