AUTO WINDOW
CANDO
AUTO WINDOW
Unread post by CANDO »
I have just acquired a new Berlingo multispace. The hand book states that the drivers electric window will fully lower or raise with a longer touch on the switch. I can get it to auto lower but not auto raise.
I have not had chance to talk to the dealer yet. Just wondered if any owners can tell me if this is normal or a fault.
Stuart McB
Unread post by Stuart McB »
Has it been programmed or the battery been off. The wifes Megane has to have the window programmed when the battery is off. Raise window with ignition on. Keep the switch in the up position for approx 7 secs then push to go down, lower and then it should go up on the one touch. Hope this helps.
Homer
x 16
Unread post by Homer »
I had trouble getting the one touch system to work on our work's Xsara.
Until I figured out it's not a long press/ short press sytem. To get the one touch open/close you press the button a bit harder.
