Xantia brakes
nelsonriddle
Xantia brakes
I recently had the brakes repaired on on '95 Xantia LX TD. I needed pads and discs front and rear. Having had this done, the grinding sound that previously occured had gone, but the brakes felt hardly any more effective. They need a lot of pressure to bring the car to a stop and the effort to the brakes seem to fade (needing more pressure on the pedal). Any ideas what could be causing this as the brakes are virtually brand new.
thew
jloner2
alan s
- RIP 2010
- x 6
If the pad material is harder than the originals were, that will have this effect. They could be taken out & roughened uo, being careful not to inhale dust particles. If air has got in, it is usually easy to pick with a spongy pedal when brakes are applied.
I would be more inclined to think that your problem could be that the pistons are sticking in the brake cylinders. Usually it is a wise move to take out, clean up & relube with LHM & refit when brakes are repaired, particularly rear ones. That would be where I would start.
