bleeding brakes!!!
andscenic
bleeding brakes!!!
Unread post by andscenic »
is it okay to pressure bleed abs systems with a gunsons eezee-bleed, i have a 98 scenic and in the haynes manual it says you shouldnt pressure bleed abs systems? is this right?
any help please andy...
beezer
Unread post by beezer »
The Gunson's will be fine. I can only imagine that the Haynes book is referring to the method of building up pressure with the brake pedal before a second person opens the nipple or some other high pressure method.
arry_b
Unread post by arry_b »
I had no problems on the wife's old Cavalier SRI with ABS using an eezibleed.
Did it exactly the same as any other car I've used it on.
Stuart McB
Unread post by Stuart McB »
Am about to do the wifes Megane Convertible, when pushing the caliper piston back just undoe the bleed nipple as the fluid will then flow straight out instead of back in to the system.
