OK, I know I should have done this anyway. Had the belt changed 2k miles ago at 120k. Within ten days the water pump gave way. By leaving the pressure cap off it lasted until I could get it back to the garage.
The lesson is to replace the pump regardless at the second belt change. It is after all only around £30 or so. Same goes for the tension pulley.
I am now £200 worse off.[:(!]
1.9D water pump & cam belt
Stuart McB
Robin
Stuart McB
