Rattle/Noise
shezads
Rattle/Noise
I'am getting a rattle from the engine - its a lot noisier then usual - sounds like the a tractor. It sounds like its coming from the cambelt area. Drives fine, just a lot noisier then usual - getting a vibration through gearbox. Don't think its an engine mount - as its doing it on idle - does really increase/decrease as you accelerate.
Any ideas.
Did have the head rebuilt after cambelt snap about 2000 miles ago. Has run fine - although it engine did seem noisier to me. Damage to original head was two bent valves and broken cam - all replaced.
Car is a 94 ZX TD
Any ideas? Will be getting mechanic to have a look today.
Any ideas.
Car is a 94 ZX TD
- x 1431
beezer
shezads
***************Update*******************
Had mechanic look at (or rather listen to) the problem. Noise seems to be coming from either:
alternator
power steering
tensioner (for above)
There also seems to be very fine reddish orange dust on the oil filter and areas surrunding the back of the alternator - looks like copper dust.
Seems to me the alternator is failing? The only explanation is the alternator coil/insides.
Will look at replacing the tensioner as this seems a little noisy - and may look at sourcing a 2nd hand power steering pump as this has a very slight leak! May as well get the whole lot done while we're there.
This is on top of the wishbone (probably replace both)!!
Looks like an expensive month [:(!]
Ah well at least its not the engine valves/conrod etc.
P.S: Does any one know if the following parts of a xantia will fit the zx (same engine, 1.9 td or hdi?):
Alternator
Power steering pump
Cheers - would be of great help.
alternator
power steering
Alternator
Power steering pump
jonathan_dyane
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by shezads</i>
alternator
power steering
Alternator
Probably
Power steering pump
Certainly not; the Xantia power steering is run from the centralised hydraulic system. For an alternative parts supply try 306 or *possibly* 405. I would imagine there would be more ZX's in scrapyards...
alternator
power steering
Alternator
Probably
Power steering pump
shezads
Does anyone know if the the power steering pump is the same on the xsara/ 306/ berlingo - on later models?
E.g. - 98 onwards 19 td.
Is the N/A diesel the same power steering pump? -As long as the same car is non-air con?
I'am guessing the alternator is the same.
Help much appreciated. Would save me alot of money!
shezads
Sorry to keep posting about this, but need all the help I can get.
Assuming the rattle/noise is coming from the alternator - can this be fixed - as it is charging ok? There is what looks like copper dust being thrown around - which can only be coming from the alternator (right?)- does this sound like the bearings? There is no play in the alternator pulley - I would have thought that if the bearings were going/gone or it was about to seize then there would be some play?
Thanks for all your help.
beezer
Dave Burns
There are sublte differences in the position of the mounting bolt holes down the model years, I recently changed an alternator on my zx td with one from another zx td, it wasn't the same, but I usually have a spare engine or two lying around and was able to swop the pump/alternator mounting bracket for the right one to fit that alternator.
An alternator doesn't have a comutator it has slip rings, if the bearings are going down the shaft could be running out of true or oscilating and the slip rings could be suffering as a result.
Dave
Dave
beezer
madasafish
shezads
oilyspanner
shezads
shezads
Latest update:
Whilst taking the alternator out & speaking to the mechanic, noticed that the reddish dust was not on the back cover of the alternator itself. If the dust came from the alternator - then that should have been covered in it.
Took the tensioner off as this was also suspect - had the alternator tested at a auto electrician on the bench - passed ok - not rattling.
Renewed the tensioner - solved most of the rattle - so it seems like that was the culprit. The noise is still there, but not nearly as loud. This seems to be coming from the power steering pump. It has a very slight leak - so I'll get this changed.
Bought two wishbones and ball joints & 1 cv boot, plus the tensioner - comes to £141!
Still have the pump to source!!
Damn this car is getting costly!!
