Urgent throttle housing enquiry.
Stempy
Unread post by Stempy »
Has it got a tiny weeny bleed hole in it?
LeFrog
Unread post by LeFrog »
I cleaned the same throttle body a short while ago. Stempy suggestion of a small bleed hole is right. From memory, one of the holes is reasonably open and the other only has a tiny hole at the end of it. Exactly what they do, I don't know. Give them both a good blast with carb cleaner.
Out of interest, why did you need to replace the potentiometer? Symptoms?
