Why is it when you get one problem the whole lot falls apart!
Not only is the engine still dripping oil - its getting worse, bigger puddles![V]
But now the brake lights are stuck on! Last time out it was the switch on the pedal, so Im beting it is again, question is what actually holds it in place?
Last time I did it, there was a plasic coller in the pedal & the plastic switch itself. Are there any nuts that have come off? (I just push it back in last time)
Ross
