tyre wear
crooser
tyre wear
Unread post by crooser »
the n/s front tyre on my xm estate is wearing on the outside,offside is ok.i have had the toe in checked and all the ball joints.i can't find any play in the suspension,any ideas anyone?
Rich
Unread post by Rich »
Hello crooser, assuming the tyre pressures and such like are correct, i'd have a second opinion on the wheel alignment. Also, if the tyre is a directional one, is it fitted the correct way round on the rim?
Rich.
Xantia Exclusive HDi.
dnsey
x 19
Unread post by dnsey »
A few years ago, I had new tyres fitted by K**** F**, and the tracking adjusted.
A couple of weeks later, the tyres were wearing severely, so I took the car back to them. On checking, they said that the tracking was miles out, and corrected it, but wouldn't compensate me for the tyre wear because it 'might have changed through hitting a pothole or something'[:(!]
tomsheppard
Unread post by tomsheppard »
Therin lies a lesson for us all. Build yourself a laser tracker for under the cost of a "professional " adjustment, learn how to use it and leave the BLXXDY MONKEYS to buXXer up Fords!
David W
Unread post by David W »
Crooser,
You may have an actual problem but if not....
This is very common on large front wheel drive cars with power steering that travel on roads with roundabouts.... and worse on a car that doesn't have its tyres up to pressure 100% of the time.
Known as Milton Keynes syndrome!
David
RichG
Unread post by RichG »
Tom,
Do you have details on how to build a DIY 'laser tracker'?
Richard
JackTar
Unread post by JackTar »
I had the same problem on my XM estate. It's usually the tyres that just need replacing.
alan s
RIP 2010
x 6
Unread post by alan s »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tomsheppard</i>
Yes, c'mon Uncle Tom, tell us more!![?][?][?][?]
Alan S [8D]
crooser
thanks for the replies,i'll start from scratch again but with a different garage.i also would like to know about a homemade lazer so come on tom you have started something now,don't leave us in suspense.
