405 diesel stop solenoid
David Humphrey
Unread post by David Humphrey »
My 405 has decided to keep running after switching off.Took solenoid off and checked it by putting on a battery and it operates.Can only assume it is the rubber seal on the plunger not sealing ? Any other ideas please
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Or the wiring to the terminal?
David Humphrey
I checked the supply with a volt meter.It has power when ignition on and none when switched off?
beezer
Unread post by beezer »
Then plunger it likely is.
David Humphrey
Is it possible to get a new rubber or do you have to get the whole bit ?
beezer
I have never had to renew so I am afraid I can't say. I do know of people who have renewed the whole solenoid and I have seen many injector pumps at scrapyards with the solenoid removed. Have you checked the chamber where the plunger seats? Could be dirt in there.
