Groaning brakes!?! (Xantia estate.)
ktaylor21662
Why should the front brakes of my Xantia groan and grind and generally sound as if the pads have worn right-down, when on inspection they are, in fact, less than half worn??
Karl
ktaylor21662
I'm in the process of replacing the front pads. Got one side done okay but broke the retaining clip in the pin on the other side and will need to get a small drill bit to drill it out. But I swear all four pads are at worst only half worn!! There, also, has been no warning light! Could the noise be a characteristic of the brand of pad? These are Lucas.
shaunthesheep
