With all this tlk of drive belts, mine finally gave up the ghost on the motorway this morning. the battery not charging light came on first then a minute later an almighty bang as the belt gave in!
managed to make it to work with the "STOP" lighst illuminated and the suspension was really low! this made going over speed bumps very intersting and a few scapes occured! Anyway, the car is now in work standed in the car park cos it has a speed bump at the exit.
If i could get it over the bumps, how long would i be able to drive it before i have no breaks what so ever? i used 1st gear to slow the car down on the way here so i didnt waste any of the brakes i had left. i could easily drive it home on the hard shoulder without worrying about brakes. its just when i come off the motorway and hit the traffic i need to worry!
no brakes!
pete_wood_uk
I presume this is a Xantia or BX? I must admit that at this point I'd call AA Relay
. However, your handbrake works on the front wheels...
Personally I wouldn't dare drive it home. Could you ask a colleague to run you to the nearest Cit dealer, pick up a new belt and fit it in the car park (if that's possible without major dismantly, I guess it depends which model you have...).
Pete
Pete
espzetec
G4EIY
Kowalski
- x 1431
I think you've got a bigger problem than you think:
"the battery not charging light came on first then a minute later an almighty bang as the belt gave in!"
I wonder if you're going to find the alternator has seized up. Did it squeal a lot while the light was on? Happened to my BX - except as my wife was driving it around town it just stalled the engine, and wouldn't restart till the belt had been taken off.
espzetec
Panjandrum
arry_b
espzetec
beezer
Scrappie seems a good idea. Try http://www.247spares.com/ you will probably have to buy a complete pump. You apply online and then you get phone calls with quotes.
espzetec
beezer
