I have a 306 with deadlocking, transponder but no alarm.
Something seems to have happened to the key (like it may be Kn***ered) in that it will not lock/unlock the doors. When pressing the lock button, the red light does not come on, but does flash once after it is released. The 2nd key works fine and the red indicator light comes on when pressing the button. This would seem to show there is a problem with the key sender. Peugeot charge a lot to provide a new key and match it to the transponder. A friend who fits alarms and makes control units for a living says Peugeot are the only ones who can sort this out on their bay as a new key needs matching to the car (with the 4 digit code etc).
Is there a way?
Oh, tried new batteries!
Dave
Runs but wont lock/unlock
PowerLee
Dave1
- x 3
PowerLee
You can just swop the metal key blade & the transponder chip over to the new key, Be carefull with the chip, its small & black & easy to lose!
If you have or can borrow a small wattage soldering iron you can try reflowing the solder joints on the pcb to see if that helps fix the key, Seeing as its broken already you cant really lose anything by trying.
samcro
Dave,
Just to clarify..
Have you got two keys with 'zapper' central locking units in them? One works fine and the other not?
Im led to believe that the code such keys send out changes each time you press the button. ie it advances to a new code so it never sends out the same one twice. When the unit in the car receives a signal from the key and locks/unlocks, it also moves onto the new code. The car will accept the current code or a number of future codes (incase you press the button away from the car and advance one code and not the other). This code is NOT the 4 digit code from peugeot but is derived from that.
Just to clarify..
Dave1
- x 3
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by samcro</i>
Dave,
Just to clarify..
Hi samcro,
Yes two keys, one works. However, the faulty key's indicator/function light does not light up when pressing the button, which leads me to think it is faulty. It flashes after pressing it. The "good" key has a light which comes on when you press either of the butons.
Dave
Dave,
Just to clarify..
Hi samcro,
Dave
Dave1
- x 3
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Peter D</i>
How about a new battery in the Fob. Regards Peter
Peter,
tried this as per the note on my post
Peter,
Peter D
Sorry missed that.
Right I suspect the smal microswith is away with the fairies and need to me replace, Perhaps you mate can do that. I have replaced several of these on VW fobs. Get you mate to meter the switch I suspect that it is only powing on for a split second then again on releasing. Regards Peter
samcro
Dave,
Don't take my word for it, but it could be that the non-working key has got too far out of synch with the code in the car (see what I said previously about car and key fob advancing to a new code). Hence the light coming on after pressing the button. ie. maybe an indication that its attempt to lock/unlock the car was unsuccessful.
Unfortunately i've no ideas on how to verify this or rectify it.
TomH
solara
samcro
PowerLee
Dave1
- x 3
With both keys in the house away from the car, one keys lights up correctly and the other flashes after pressing it. Neither would know if it had unlocked the car or not. Hence I feel the key is faulty rather than differing in signal to that which is required. I feel the easiest and mid priced method will be to just buy a new key, program it work the locking and swap the chip as PowerLee suggested. I have looked on ebay, the infra red ones are not in the majority and there are things stated like "it lights up but cannot confirm it works so sold as seen" (£30 too.) I can get a new one for not much more. I don't mind that too much, but I do not like the extra charges for the garage labour(leaning on the car,having a fag, displaying driving ability in the workshop), so chip swap seems best, unless of course, you know better!!
As it stands I am happy with the help given which will save a few pounds and keep the car away from the Pug dealer.
