could anyone tell me what type of seals are used under the torx bolts on top of the hydralic pump ('o' rings etc), the torx bolt look like they have been installed to blank off un-used outlets. my local main dealer told me that they no longer do the seals for my year, oh by the way it's 94', L reg,
thanks dom
xantia hydralic pump seal's
Dave Burns
If you are talking about the six large head torx bolt's arranged radialy around the pump, these blank off the actual pump cylinder's.
They will more than likely be a standard type 'o' ring, unscrew one and find out, watch for any bit's like piston and spring's falling out, also because the pump is lower than the reservoir it may start to syphon the LHM.
Dave
Dave
shaunthesheep
Dave Burns
porgy
