clarion pu1633a help pug 406 2000reg
nicmcd
Unread post by nicmcd »
I have recently bought a second hand stereo for my 406 HDi reg. 2000. The guy told me it would need to be reprogrammed to my car as it doesn't have a code system. I tried to fit it anyway just to see if it would work. And no lights at all. Should it at least light up or does the reprogramming switch it on. Also any idea what the cost is and is there any other way to get the thing to work.
Hope someone can help.
pumbaah
Unread post by pumbaah »
hey, i believe you have to programme the code back in, you may need to bring it back to the dealer as i m not sure if u need the diagnostics for the programming or just to input code only....otherwise it may not work.
reblack68
Unread post by reblack68 »
The backlight probably isn't working. Try looking at the display with a torch, which might let you know what's happening.
I believe these units can be decoded by serial number.
