Xantia TD (95N) - help needed!
smashymike
Hi - can anyone tell me what the warning light to the right of the ABS light is, mine's been flashing at switch-on but extinguishes when i drive off. Coud it be the infamous water-in-fuel light and if so how do i fix it??
beezer
JohnD
- x 72
dnsey
- x 19
np
Sound like the low engine oil level light.On mine,i have the abs light(org)batt light(red)then the oil level light.When mine gets a little low,or if your parked at a steep angle,it will flash for about 10 secs when you start up,then go off.It comes on on mine when the engine oil goes below the normal?middle mark on the dip stick.
