xantia cooling fan switch
just bought a '96 1.8sxi - lovely car very pleased... only the cooling fan doesn't kick in. top and bottom hose plus rad are all getting hot, temp guage is hitting 105 before i turn it off (still no fan). fan works when connected direct to the batt,motor cools nicely when the car is moving. its the cooling fan switch i hear you cry!.....only i cant find it and its driving me mad. i even bought a manual that only told me what i was expecting ... that its on the radiator. i dont have a/c so i dont think i fall into the bitron catagory....could i possibly have been duped with a rad from an a/c model? please save my sanity!!![xx(]
- Contact:
The temp sensor should be on the radiator on the lhs as you look at the car about half way down the rad, I think that there were a few models with the sensor on the rhs of the rad, if the hole is just blanked off with a plug, is there a sensor on the thermostat housing where it emerges from the block? is it an 8 or 16 valve car? I think the rads were all the same, I have a model with air con but the rad is the same, there is just a blanking plug where the sensor should be. If the hole is blanked off have a look for a connector with 3 wires (fairly heavy duty ones) coming to it somewhere near the blankig plug,.
Ha just looked in the ha***** book of lies and it appears to be a single speed sensor so only 2 wires, now I would be surprised if it were single speed so this may be another H**** F*** up, maybe one of the other guys with a car the same as yours will come up with a more definitive answer. Sorry to have rambled a bit,
Pete
________
Zx14 Vs Hayabusa
Pete
________
Zx14 Vs Hayabusa
yeh there is a blanked off section about half way down on the lhs but nothing elsewhere on the rad. there is nothing obvious around the thermostat, would it be on the rear side of it? there is an unused connector with exactly the right length of cable comming from the loom at the bottom of the rad...hmmm
thanks for your prompt responses
ok im a bit confused but this is the situation as i see it - 1996 xantia 8v 1.8i with no a/c but with a bitron sensor (brown connector) at the rear of the thermostat housing (almost impossible to see) with a controller (black box,4''x2''x1'', with bitron written on it) under the engine compartment fuse cover.has anybody else experienced this configuration?.... i thought only a/c models have the bitron thing???
im sure you can get models without a/c that still have a bitron box,the thing you see in the fuse box may just be a normal relay (alot of them are also made by bitron),the actual bitron box is located under the l/h headlamp and has a 15 pin connector on it.disconect the brown sensor on the thermostat housing & the fans should kick in at full speed.
[:)]DEEP JOY [:)]problem solved, i disconnected the sensor after a struggle and some skin from my knuckles and to my surprise the fan did not kick in! this promted me to recheck all connections with the sensor still disconnected - hey presto dodgy connection on the fan itself, a squirt of WD and a cable tie later and im grinning from ear to ear.
thankyou all for your help - an excellent forum by the way, keep up the good work[:)][:)][:)]
