EGR valve on hdi xsara
drpau
Unread post by drpau »
Will disconnecting the EGR valve on a Xsara HDi result in the engine management light coming on? I remember quite a few rover diesel owners used to do this to give them slightly better performance.
What do you think? Yeah or neh!?[:)]
x 1056
Unread post by wheeler »
as long as you just block off or clamp the vaccum pipe & dont disconnect the electrovalve it wont bring the eml on.i dont really think it will do anything for the performance though to be honest.
drpau
wouldnt you get a better burn of fuel though as your not getting any of the 'dirty' exhaust gases recirulated? If not, sod it Ill leave it as it is!
x 1056
EGR on an HDi is only operational at idle & light throttle,whenever you need power the EGR valve is shut off by the ECU anyway.
