An annoying but hopefully not too serious problem happened earlier this week.
On activating the central locking on my ZX Dimension 1.4i, the doors unlocked as usual but the hatchback has stayed firmly locked. I've tried unlocking the back with the key but to no effect. Anybody got any ideas or tips to help rectify this problem, I can't cope without the use of this space.
Many thanks in anticipation..
Citroen ZX - can't open hatchback !!
arry_b
Give the tailgate a bash with the palm of your hand a few times while plipping it open a few times. This should get it open eventually.
Once you've opened it, check that the catch on the body, and more importantly on the tailgate is secure.
Mine have an occasional tendency to loosen off, needing a couple of turns on the 10mm nuts to stop it doing what yours is doing now!
Twiss
strollerA
What can I say but MANY THANKS to arry b and Twiss.
I've just read your replies and gone out in the dark and tried arry b's idea of hitting the lock and at the same time operating the remote a few times and it worked !!! The hatchback now opens again. I'll have a closer look tomorrow in the daylight and see if anything is loose.
I'm just glad that I don't have to take Twiss's advice, didn't fancy scrambling about trying to access the lock from the inside.
Thanks again to you both.
arry_b
