306 1.9td Vacuum pipe
Crow36
Unread post by Crow36 »
hi would anyone be able to tell me where abouts the vacuum pipe is located on my 1.9td 306. I am currently searching for it but havent had much success. I have been told that it can be fount at the top left in the engine bay. I have looked but i can see 2 black pipes. Both of which i havent a clue what they are. Any help would be great thanks [:)]
beezer
Unread post by beezer »
Do you mean the servo hose?
bad driver
Unread post by bad driver »
The vacuum pipe runs from the vacuum pump on the right hand side of the cylinder head to the brake servo unit back left of bay. The 2 black pipes you are refering to are for the diesel.
beezer
Looks like we assume the same thing BD. The servo unit is the metal canister thingy that the master cylinder goes into (where you fill with brake fluid).
