smoky diesel while engine pulling
nrocks
Unread post by nrocks »
my rover 218 td seems to be smoking a lot when engine at lowish revs.., when pulling away , 1st , 2nd and mainly 3rd gear...only really noticed it at night when headlights behind me ...any thoughts
arry_b
Unread post by arry_b »
Yep, it'll do that. Don't worry.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Always looks its worst when you floor it with headlights behind you.
np
Unread post by np »
If the performance is ok,& it doesn`t need constant topping up of oil,i wouldn`t worry to much.Mine is the same,upto about 3500 rpm,then it clears.I followed a brand new Merc E320 diesel the other day in day light.You should have seen the black smoke coming out of that!
