- x 8125
Dormouse
- x 696
The next thing that caught my eye was this
OOPS! I was way off, but at least you know I looked now.
- x 7163
Your effort was noticed and appreciated, and it was a rather imprecise whatsthisthen!
As it turned out this morning water was flowing through the pipes. Not that the heating had been left on low...I got the boiler's not working call late on last night. Knew what it was but I wasn't going to climb up a ladder in the dark to pour boiling water on the external run of the condensate drain to melt the ice.
That was a first thing in the morning job, and thankfully its back working. Will have to do something about that, longer run inside the house before it exits the external wall but a bit of awkward geography to negotiate based on the siting of the boiler and a long run to the existing drain.
Just along from your old stomping ground and much appreciated DaveDormouse wrote: 14 Dec 2022, 09:21 I couldn't resist adding this picture from this morning courtesy of Fife Weather.
Sunrise over Aberlady, just for Neil.
- x 7163
Why that ends up retained in the box I have no idea. A simple section of plastic drain pipe of a useless size.
Dormouse
- x 696
Join the Club!
I have boxes of #### too and LOML cannot understand why I keep them. However, when all the "little" things that go wrong get fixed, I don't get any thanks for sorting them out. My next door neighbour has twigged it though and realises I can probably fix most things but, even then, the two of them gang up on me to clear all my #### out but agree I am worth keeping "just in case".
Dormouse
- x 696
Ever had the feeling they are just patting you on the head?
Back to the kennel.
Back to the kennel.
Dormouse
- x 696
[Just along from your old stomping ground and much appreciated Dave
That was a first thing in the morning job, and thankfully its back working. Will have to do something about that, longer run inside the house before it exits the external wall but a bit of awkward geography to negotiate based on the siting of the boiler and a long run to the existing drain. ]
Just one of the reasons I persist with my Baxi. I have a complete fire and back boiler for spares or replacement just in case - haven't needed any yet and the Baxi is simple to service.
Just one of the many "piles of ####" I keep.
In the garage trade that was called the glory box. Anything that might be useful and often was. When you took apart a gearbox synchro and one of the ball bearings shot off into space get out the glory box.
Onlinemyglaren
- x 5672
Most places I worked (and here at home) have similar.Dormouse wrote: 14 Dec 2022, 10:16 Join the Club!
Mostly tolerated but the first place I worked here they were forbidden. My line manager called it his 'glory box' that we were forever hiding from the MD.
Next place was worse, we had stacks of them. When the annual audit came around they were all hidden in the false ceilings until that MD had done his rounds.
All crap but you know that as soon as it is dumped it will be just the things you need.
- x 8400
Salcey Forest looking very festive this morning...
I went there for a very pleasant run in a winter wonderland
The coffee and flapjack at the cafe went down rather well too...
Dormouse
- x 696
At least you have the real white stuff. Even my path salt is freezing into lumps. Our outside deck is still white with frost and is showing no signs of lifting. Bitterly cold when you venture outside too. I had to hammer the bin lids open to put stuff in the bins - they were frozen solidly shut.
- x 8400
Yew, proper snow down here
I had to do the same with my garden/food waste bin... Levered it open with a pry-bar!Dormouse wrote: 14 Dec 2022, 14:22I had to hammer the bin lids open to put stuff in the bins - they were frozen solidly shut.
Dormouse
- x 696
Dormouse
- x 696
It has to be pretty cold to freeze water foam that quickly!
- x 8400
