And then couldn't work out how to get down again...
Catch All - the place for anything you want to discuss off a specific topic
- x 8417
Re: Catch All - the place for anything you want to discuss off a specific topic
I was on holiday in Santa Cruz de Tenerife, a Spanish guy beckoned me over to the sea wall pointed to a spot and said "Nelson's arm." doing a chopping motion with his hand.
- x 3565
Here's a screen shot of the tracking details for an item I've bought on The Bay of Plenty. It's not been delivered here yet.
Can anyone who's qualified in Yodel work out what's going on ?
- x 8137
It seems simple enough to me bobins -
:lazer: :missile:
Means about the same!!
:lazer: :missile: Means about the same!!
- x 1075
Is it Origami, death from a thousand paper cuts would be aweful!CitroJim wrote: 26 Nov 2023, 06:06Nope, not kick boxing Ryan, something far more lethal. And not needing good knees either, although good knees do helpRp0thejester wrote: 25 Nov 2023, 21:46 I'm just hoping CitroJim does Kick Boxing, with his Dodgy knee I might have a chance![]()
Champion of Where's CitroJim
- x 8417
Believe me, paper cuts are the worst. I got a load when I was engaged in a marathon shredding session a while back. They go deep, hurt and take ages to healRp0thejester wrote: 29 Nov 2023, 21:06Is it Origami, death from a thousand paper cuts would be aweful!CitroJim wrote: 26 Nov 2023, 06:06Nope, not kick boxing Ryan, something far more lethal. And not needing good knees either, although good knees do helpRp0thejester wrote: 25 Nov 2023, 21:46 I'm just hoping CitroJim does Kick Boxing, with his Dodgy knee I might have a chance![]()
I was once with the Bank of Origami - it folded
- x 8137
Being aware of Forum rules I have chosen to link this video here as the basic subject could be described as political. Personally I see this as eductional where the subject is climate change and I have no desire to generate any political discussion on the subject, simply to bring this informative video to other member's attention!!
- x 1075
I've may of said a few times that my 14yr old son does videos on Tik Tok/Instagram. he's finally sent me 2 that I can share. He writes the Script and inserts the vids, clearly not his voice. Well was gunna post but MP4 isn't accepted
- x 1940
Try posting the link to TikTok. Maybe it'll be treated the same way as YouTube vids.
- x 1075
Lmao
- x 1075
I'll suss it at some point
- x 3565
Calling all bods who know about such things !
Some time ago I was given an old small genset in a non-working condition. It dates from 1969-71 -ish. The engine is an old Honda G40 - these were the early days of the small, ubiquitous, portable Honda engines, unfortunately the engine is a bit past it. The design of the genny is that it is belt driven rather than direct coupled like modern ones so that means I can just drop in a spare engine to make it work.
However....... when I looked into the genny control gubbins I hesitated.
Can anyone who knows about such things have a look at the various electronic bits in the picture and comment on what they think i.e. 'Wouldn't touch that with a barge pole', 'No problem, easy to check and easy to replace u/s bits', 'That'll go bang as soon as you make power' etc, etc.
I don't actually need another genny as I have a few already
but I thought it might be fun to get this one going, and I have suitable engines for it sitting in the shed.
- x 8417
I see nothing frightening in there Robin... Check the two capacitors are OK, especially the electrolytic and that the bridge rectifier is good (i.e. no shorted diodes).
The generator looks as if it will be self-exciting using residual field magnetism and some of its output is rectified and more or less manually regulated via the front panel voltage control rheostat to give the required DC voltage to the field coils to give approximately the right AC voltage out.
It won't be terribly well regulated vs. varying loads so hence the manual adjustment! It'll be a bit rough and ready but ideal for powering non-critical stuff...
In truth, so little to go wrong there and if there is, easy to fix... That electrolytic is the bit most likely to keel over but going by the pictures it doesn't look too distressed.
- x 3565
That's very reassuring, Jim, thanks for the info. I think I'll replace the 2 crapacitors as a matter of course...... providing they're not silly money.
- x 8417
I wouldn't bother to change the capacitors unless they test faulty, either open, short or leaky, Robin. Or the electrolytic looks about to spill its innards.
Also, the one that's in an oval case looks like a motor-run or motor-start capacitor and is a special type. It must be replaced by a compatible item and not just any old capacitor. These, in particular, are usually reliable. It's electrolytics that give most trouble.
Good luck with it and let's hope it produces a few colts very soon
