C5 clutch dual mass or single plate?
darbuck
x 291
Re: C5 clutch dual mass or single plate?
Unread post by darbuck »
your a scary man Alasdair :rofl2: my mk1 c5 has an smf in it a couple of years now and there is no excessive vibration and no difference in gear change as for electric but does the charge time not scare anyone and I can only assume that night driving will reduce the operational time and range.
Darren
hirsty
x 9
Unread post by hirsty »
Re electric trucks, couldn't an additional trailer just carrying batteries be useful. They could switch to the spares when the fixed batteries get low like the old Jaguar fuel tanks. :shock: [-X :-D
hirsty
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
darbuck
x 291
:rofl2: :rofl2: it all seems a bit nuts to me, surely the hydrogen model would be better.
Darren
aneesh84
x 29
Unread post by aneesh84 »
mark2256 wrote: 28 Mar 2017, 22:27 Just replaced the DMF and Clutch on my 2006 C5 1.6 hdi at 111000 miles managed to pickup a new kit of Ebay for £190.00 inc. postage. Also recommend changing the clutch release fork, clutch release folk ball joint and first motion shaft support tube and oil seal. As a preventative measure I have also replace both drive shaft oil seals, the offside drive shaft support bearing, checked both wheel bearings (replaced), checked both bottom steering swivles (replaced) and fitted new front disc's and pads. A friend have a single mass flywheel and clutch fitted to his 2005 1.6 hdi back in November 2016 I when for a drive in it and the vibration was atrosious last month whilst drive in the M1 the engine died he had the car recovered to his home and on stripping it down he found the crankshaft had snapped, bent 8 valves and holed 2 pistons expensive mistake fitting a single mass flywheel?
Can you confirm if the kit was Valeo Kit4P?
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
