Skull
(Donor 2026)
x 382
Re: Citrojim's AX, Pixo, C3, Running and Cycling Tales
Unread post by Skull »
Michel wrote: 26 Sep 2023, 07:22
Skull wrote: 22 Sep 2023, 11:16 I saw ‘waterproof’ cycling sock advertised at Aldi :^o It seems I haven’t learnt …..
From 40 years cycling and 30 plus years of motorcycling, I can tell you there is no item of clothing that's truly waterproof
I’ve fallen for their lies again :roll: although I did have a one piece Frank Thomas that was 99% waterproof and a navy immersion suit that used to steam you alive :lol:
Gary
Michel
Unread post by Michel »
Skull wrote: 26 Sep 2023, 08:43
I have one of these, I've probably used it five times. The last time, oddly, after a few years , was this morning. Had to go to dentist 20 miles away, can't physically drive the car at the moment because of my ankle, so had to take the bike. It looked like it was going to p1ss down, so I put it on over my summer bike jacket and bike jeans, as it also steams you alive. I can wear it with summer gear as mentioned, when it's around freezing and still I'm not uncomfortable at motorway speeds!
https://www.sportsbikeshop.co.uk/motorc ... prod/71184
Of academic or journalistic interest only Jim, this is by far the most expensive AX I have seen come up at Auction recently.
https://www.classiccarauctions.co.uk/19 ... rwick-0923
x 1083
Unread post by Rp0thejester »
Never in a million years is someone gunna pay that!!! As a younger generation person here it ain't gunna happen.
x 8162
I fear you may be in for a surprise there Ryan, with that mileage and 1 owner history it is the sort of car that will appeal to a serious Citroen collector. I personally think it will make 8-10k but only time will tell!! :-D
x 1083
If it was top of the range sports model then maybe 7k as a future investment but I still doubt it. A VW Corrado however....
x 2006
Unread post by Stickyfinger »
My bet is that it will hit 12K....low miles etc etc....that will go in a collection never to be seen again.
x 8440
Rp0thejester wrote: 26 Sep 2023, 20:50 Never in a million years is someone gunna pay that!!! As a younger generation person here it ain't gunna happen.
If I had a spare 15K burning a hole in my pocket, I'd pay that for a very lovely GT... Not that one though as it's a series 2.
NewcastleFalcon wrote: 26 Sep 2023, 20:39 Of academic or journalistic interest only Jim, this is by far the most expensive AX I have seen come up at Auction recently.
That is a lovely one Neil and thanks for posting it up. Not for me as it's a series 2. Now if it was a series 1 and as said above, I had lots of spare money, I'd buy it but it's academic as I haven't - not with what's going on in my house...
Lots of progress yesterday and Monday...
I did all the new plumbing yesterday, including a proper replumb of my outside tap. Happily, I had a complete absence of Welsh vegetables, bar a couple of tiny weeps on a couple of compression fittings I'd not nipped up quite tightly enough.
I did my usual and made the soldering practically invisible... I enjoy plumbing and did all I could to make it as neat as possible. It is an order of magnitude better than what was previously there... A right old leaky bodge-job...
I used, for the first time, lead-free solder (as the regulations says I must on potable water systems) and water-soluble flux that's safe on such systems. I had to practice a bit to get the 'knack' of using lead-free and found it absolutely fine. I was intrigued to see my gas man used MAPP gas when he plumbed in my hob gas feed. You do need a bit more heat with lead-free but a high quality propane torch does the job. I have a superb one that runs off a Calor Gas cylinder.
The first draw of water out of the new pipework looked like frothy milk! That was the flux washing out of the system... It looked spectacular :)
My old washing machine has done it's last wash and today I do my first in my new one :D
Skull
(Donor 2026)
x 382
This is what some ‘plumber’ did over the years
Skull’s Outdoor tap
Skull’s Outdoor tap
No need for that, love a bit of polished copper 👮???
Gary
x 8440
Gosh Skull, that's even worse than my old plumbing :shock:
And all that excess solder on those copper elbows :evil: Horrible and shoddy :( And plastic elbows too :twisted: Can't quite trust plastic yet at mains pressure when hidden and inaccessible behind kitchen units...
x 8440
Spot the solder :D
Yes, yes, I know... If you really zoom in real close you can see a bit ;) :lol:
Skull
(Donor 2026)
x 382
I bet that’s better than the gas blokes soldering :wink: ….I’m sure I spent more time cleaning up solder joints than anything else at college :roll: …
Gary
x 8440
Skull wrote: 27 Sep 2023, 10:06 I bet that’s better than the gas blokes soldering :wink: ….
My gas bloke does it so well it's a joy to behold :)
Skull wrote: 27 Sep 2023, 10:06 I’m sure I spent more time cleaning up solder joints than anything else at college :roll: …
Time spent cleaning up is the key to a good joint Skull :) I take ages using steel wool until it shines like Bristol bacon :)
Skull
(Donor 2026)
x 382
I can’t find a ‘finished’ photo but I remember it was a 10 hour job sorting that mess out to - copper, clipped, sleeved through walls, isolation valves, sealed holes all required before a clean and polish ….I couldn’t make a living at it ….takes me far too long to do it properly :oops:
Skull’s improved version
Gary
x 3565
My plumber made sure that all the soldering he did at mine with end feed fittings was fed in round the back of the fitting where you couldn't see it 8-)
Top tip !
