I am an Activaist-v6 and a 2.1Estateerr
svip
x 10
Re: I am an Activa owner...a V6 and I am an addict
Unread post by svip »
May I enquire on which specific models of Mintex pads and Brembo vented disks you got?
x 2009
Unread post by Stickyfinger »
Standard road pads and V6 callipers & disks ,vented type. Standard fit on my car.
Measure your disks and check.....some cars have the large type fitted as standard, all cars can have the larger type fitted. Many have been upgraded.
I have a set of callipers if you need them.
daviemck2006
x 485
Unread post by daviemck2006 »
You must drive like me Sticky. I rarely use the brakes, lift off approaching the corners, then gently on the throttle in the corner. It's easy in the activa, just go everywhere at 60! Never slow down, mine goes round every corner on the roads I'm usually on at 60. Unless there are people in lesser cars, eg audis and beamers slowing down cos they are scared [emoji12] [emoji13] [emoji23]
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 2009
60 ??....hahaha
But yes, drive it like a GT car....smooth and steady. I was taught that very early on in my driving life. It is why I like torque in an engine more than revs.
daviemck2006
x 485
Can't beat the torque. Far better than frantic high revving small multi valve petrol units.
Peugeot boxer 2016
In the family
x 2009
Depends on the car really.....the C5, the Xantia and my Healey are all quite heavy really so torque is needed.
All the cars I have liked in the past have been as well for some reason, my old SAAB 900t's ect were , even the Beetles were vrs Mini's ect.
I never got totally comfortable in the Lancia Inter Evo I has for a short while either, also the Calibra Turbo, the exception to that was a Lancia Fulvia which I still wish I had today, just a fantastic little thing.
daviemck2006
x 485
I prefer a bigger heavier car for out of town cruising. The 107 is good around town, as long as you use the accelerator pedal as an on off switch lol. Not how I like to treat a car, but it's what it needs to go!
Peugeot boxer 2016
In the family
x 2009
Same with our little Kia...and it is an Auto as well....full go go and just use the overdrive button :)
chinkostu
x 30
Unread post by chinkostu »
Stickyfinger wrote:Standard road pads and V6 callipers & disks ,vented type. Standard fit on my car.
Should be added that the 288mm bosch calipers can't be fitted to 283 or 266 hubs as far as i'm aware.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 2009
did not know that....so ANY 288 disk/calliper set up must have the special hubs for them to upgrade.......learn new every day
x 2009
So....New tyres all fitted and out today on the car. What a differance , more grip, stiffer in the corners....I like these tyres :)
Also fitted Xtreme White Zenon gas bulbs....will try those later tonight. I Fitted all 6 forward lamps with them as I scored an EBay bulk buy of 10x.
And my rear view mirror FELL OFF :) !............so I took the opportunity to fix it right up high on the screen to improve cross car visibility at round-abouts/inclines ect.
x 2009
Scrub the lighting test....its bloody snowing !
x 8470
Stickyfinger wrote:Scrub the lighting test....its bloody snowing !
What? down your way? You sure?
Mind you, the railwaymen did used to call your neck of the woods 'Siberia' back in the days before Beeching wielded his axe...
x 2009
Yep....about 1 inch and wet.....it did not sit for long but confused the hell out of the chickens who had not see it before.
x 8470
Stickyfinger wrote:it did not sit for long but confused the hell out of the chickens who had not see it before.
Like an icy pond can confuse a duck...
