DIY Car Maintenance with function over finesse!!
x 8171
Re: DIY Car Maintenance with function over finesse!!
Indeed Paul, I gave it its initial run for 6 miles to ensure all is good, which it is. Further bedding in tomorrow as it will get a 60 mile round trip to meet Jim for lunch. I use lanes for all bar 3 miles of B road so they should be properly sorted by the time I get home.
As for the speed of the job it truly is amazing how the power tools make all the difference, big rattle gun for wheel nuts and jacking, power ratchet for bolts, drill with wire brushes and cordless vac for cleaning and last but not least the bench grinder for deburring any rough edges on the pad backplates. Only two of the eight needed thst where the tips were a tad sharp!
Total time spread over the two days about 3.30 :-D
x 8456
Excellent work Mick :D Pleased all is done and all is good :D
PaulC5
x 721
Unread post by PaulC5 »
Power tools, perhaps I need to invest in them with Einhell I guess being a good choice.
x 8171
While awaiting the new bath to be delivered I decided it was time to start preparing the garage for its new shelves which are due tomorrow. Basically I am replacing the original 4mm MDF shelves with 12mm hardwood ply in an attempt to stop them sagging. This is the starting point:
The existing racks with warping shelves.
Of course inevitably it is also the right time to rationalise the contents to make more space available so I started with the brown Gladstone bag on the bottom shelf of the right side rack. Its contents are a classic example of 'it might come in handy' stuff but I am going to be ruthless and scrap anything I don't need, but in some cases, like this one, I shall pop a picture on here for anyone who may be interested, at their own transport/postage costs, in giving the contents a new home before I take them to the recycling depot on Friday.
The top row are AF and the bottom row metric.
So if you do want anything PM me or post on here and we'll sort it out. I do not want any payment (other than postage etc) for any items I am prepared to recycle. :)
PaulC5
x 721
If you have a vehicle museum near you they might take in old tools. I have given a few to the Lincoln Vintage Vehicle Society which has a collection of mainly old buses plus some cars and motor bikes as well as some old push bikes. Things they do not use they sell on. A couple of weeks ago I gave them some Gunsons tools no longer of use on newer cars and some I will never use again - including 2 timing lights, an exhaust gas tester, multi meter with rpm and also a click adjust tappet adjuster, clutch alignment tool, valve spring compressor (made in Sheffield as well so a good one). Not long ago I gave an engine crane last used over 20 years ago to somebody who may have a use but I could not guarantee the piston so could not charge.
x 5688
Or a charity shop!
x 8171
The recycling depot we have has a reuse shop, so that is where they will end up if not claimed. The AF spanners are now spoken for!
Next to come out of the shelf was this impact driver, it has two batteries both working as is the charger, but I have three others now and don't need this one!!
The tool
The tool
The instructions with model number
x 8456
Any local 'Men's Sheds' are always keen to receive tools. They're a charity that does some good work to aid the mental health of lonely old men.
PaulC5 wrote: 31 Aug 2026, 14:12A couple of weeks ago I gave them some Gunsons tools no longer of use on newer cars and some I will never use again - including 2 timing lights, an exhaust gas tester, multi meter with rpm
I have all of those Paul and still use them occasionally on my AXs :D
x 8171
PaulC5 wrote: 20 Aug 2026, 13:42 Power tools, perhaps I need to invest in them with Einhell I guess being a good choice.
I have built my collection since buying a cordless mower and being impressed with the build quality. I have bought the vast majority from auction for between 10 and 20 pounds each.with just the impact driver and jigsaw being more. The picture doesn't include the garden items mower, fence sprayer seed spreader and pressure sprayer or the 8 batteries and 2 chargers I have accumulated!! No complaints from me and they make life so much easier. 🤠
My collection, out for rehoming in my shelves
x 8456
Gosh! That's one hell of a collection Mick :)
x 8171
Picking up from my Picture of the Day this morning I had a bit of a game changeing the wheel:
In fact I had a nightmare with it, it was too low to get any of my jacks under the front sill so I had to use the trolley jack at the back to raise the whole car enough to get the scissor jack under the sill. Having jacked the back I was about to check if the scissor jack would fit under when SWMBO came out and needed to get off to her club. The trolley jack handle was across her path so without thinking I undid the trap screw and pulled out the handle. She drove off and when I went to replace the handle having discovered the scissor jack needed another cm of clearance I realised that the actual socket which receives the handle had sprung to the upright position, completely under the car, so I had no chance of reinserting the handle to jack the extra cm. Enter my new bottle jack which I was able to manoeuvre through the rear wheel arch and under the chassis to raise it another couple of cms releasing the trolley jack for extraction and allowing the scissor jack to get under the car. I then jacked up the front and changed the wheel. What a palaver!! :-D
All down to this so I'm off to see Peter, my tyre man, and get it sorted.
The culprit!
The culprit!
x 8171
Just to complete my nightmare I had a serious problem while putting the tools away. I, possibly foolishly, used my super rattle gun to wind the scissor jack back to closed for storage and forgot to release the trigger when the jack had fully closed. The result: #-o #-o
The jack's centre rod before my error
Spoiler: show
The jack's centre rod after my error!
Just to finish the salt rubbing when I got to Peter, he repaired the screw hole in the tread only to discover a hole in the sidewall when he inflated it!! So two new fronts to be fitted, I only ever replace in pairs, when they come in. !! What a day!! :-D
x 8456
Oh dear!!! May today be a better one Mick [-o<
x 8171
You may remember my tale of puncture woe last summer, described here, and then last week's screw up described above. Well having completed 681 miles since Sunday for a viewing day at Mathewsons and a ride on the steam hauled North Yorkshire Moors Railway, I got up this morning to be greeted by the n/s rear tyre immitating a pancake. I have swapped it for the temporary spare loaned to me by my tyre man last week and then on examination found this:
Screwed again!
Screwed again!
I have a feeling that this repetition may be due to our neighbour who is emptying her Mother's garage bootload by bootload and parking outside her drive to unload. Thus I feel it is likely that the odd screw is falling into the gutter as she unloads and that is my runway onto the place I park!! :?
So now I have to replace the front pair and the rear pair so 4 tyres coming up!! :)
PaulC5
x 721
If the tread depth is good I would have that repaired. Our local Kwik Fit did not charge for the last repair but this may not happen at the others. Possibly the paperwork was too much bother as they were busy when I collected the wheel. Suspecting a neighbour I guess you will now be checking the road for screws.
