RNEG Firmware or Software
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
Samuelblue123
Re: RNEG Firmware or Software
Unread post by Samuelblue123 »
Could I please get the download for the RT6 2.86.B version for my DS4?
x 1938
Unread post by Paul-R »
I can't guarantee that it's the B variant but check your PM in a minute or two. Usual disclaimers, use at own risk, etc.
roady1922
Unread post by roady1922 »
Hi Paul, my RT6 in my C5 X7 is currently running firmware 2.77. Could you please send me the download link for the latest Firmware by PM? Thank you.
x 1938
You've read all the warnings about moving to 2.86? About moving in steps rather than all at once? And how it is strongly advised to make a backup of your RT6 configuration with MiraScripts first?
Issei
Unread post by Issei »
Hello i retrofitted a rt6 (rneg) to my peugeot 308cc from 2009 wich had rd4 as original. Now i have time and date issue whenever the car goes to sleep mode it forgetts the time and date. according to ai a software update might solve it i run rneg 2.7.5.c and ai says to me to stop at rneg 2.8.0 can someone please give me a link to update it or at least bring some light to why it keeps dropping the time and date memory.
x 1938
Not sure it'll fix your problem but check your PM in 5 minutes. Let us know how you get on.
Mathys1pienaar
Unread post by Mathys1pienaar »
Hi Paul. I noticed my situation is very similar to the situation written on the Tutorial on how to replace your SD card of a RT6 unit, where my screen is blank with no audio after using one of the 2.86B versions found on the internet, It reads and starts the installation, gives me an installation percentage twice, restarts and then just restarts the whole installation process over again. My SD card that came with the car would not read on computer, so i am assuming that it failed completely, So I had no way of using Mirascripts. Could you please assist me with a download link for this system for 2.86(or newer) so that I can test the RT6 with a version that would more likely be an actual working version?
Issei
Paul-R wrote: 19 Aug 2026, 17:57 Not sure it'll fix your problem but check your PM in 5 minutes. Let us know how you get on.
Hi you are right it did not fix my issue. But i did solve it by adding a permanent 12v to the power wire i took the same 12v from the previous screen when i had a rd4 radio. So far everything seems to work both of my aftermarket amps are shutting down. The real test will be tomorrow when i start the car will it be dead or will it start nobody knows 🤣
x 1938
@Mathys1pienaar
Check your PM in five minutes.
Victors508
Unread post by Victors508 »
Rhothgar wrote: 25 Jan 2026, 15:25
Paul-R wrote: 25 Jan 2026, 12:44 I have 2.31, 2.71, 2.77, 2.80 and 2.85 as ISOs. I also have 2.21 and 2.37 as software for a USB stick.
Can the firmware be downgraded do you know Paul? If so, I am half tempted to downgrade the 3008 back down to 2.80 for her to see if that remedies the BT ECHO, Echo, echo, ech, ec, e....
Hi Paul, could you please send me the RT6 firmware 2.37 USB version?
My Peugeot 508 SW 2011 currently has RNEG2.07.A.3.
Thank you!
x 1938
Check your PM. No guarantees, no comebacks, etc.
