C5 X7 rear hydraulic pipe-hose stainless substitute
DHallworth
x 167
Re: C5 X7 rear hydraulic pipe-hose stainless substitute
Unread post by DHallworth »
What do a set of these hoses cost?
Thanks,
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
sotirisk
Unread post by sotirisk »
I would also be interested in having a pair just for use it when needed.
Simon_C5
Unread post by Simon_C5 »
Hello Svod. I would be interested in purchasing one pair. How much to they cost and how long is the waiting time?
Thank you,
Simon
DHallworth
x 167
If you can't get a response, these are available on eBay:
Right: https://www.ebay.co.uk/itm/285318784183
Left: https://www.ebay.co.uk/itm/284982934689
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
BruteForce
Unread post by BruteForce »
I have successfully contacted Milan on the email mention ages ago on this topic - patamatbx@centrum.cz
Just purchased a LHS rear S/S hose at a cost of 90 Euros, plus post.
Looking forward to receiving and fitting it.
Cheers,
Bernie
steveclv
x 40
Unread post by steveclv »
I just had this pop up on my French C5 FB group - no idea if they are any good but maybe worth a browse for C5/C6 pipework etc
They say they will post worldwide.
https://cargomesh.com/en
wurlycorner
x 271
Unread post by wurlycorner »
steveclv wrote: 12 Dec 2025, 09:38 I just had this pop up on my French C5 FB group - no idea if they are any good but maybe worth a browse for C5/C6 pipework etc
Brilliant find, thanks!
@the-terminator this lists 3.0 HDi bits including the water pipe!
Iain
CX DTR T2 Safari (silver)
Kafzito
New User
Unread post by Kafzito »
Hi, I know the post is few years old, but still have hope that you still making those pipes, I need a very small pipe and I am unable to find it in Spain. It's just the metal parts. It was fixed in the past and the last owner decided to cut the pipe and replaced just the damage length. Are you able to do it for me?.
NOEKDESIGN
New User
Unread post by NOEKDESIGN »
Hi Svod - can I ask what you charge for Bothe left and right hand side?
Thanks!
Noek
Steven M
New User
Unread post by Steven M »
Hi Svod
I have a C5 X7 I would be interested in purchasing your left and right rear suspension pipes
I’m based in uk
Steven M
rahtzir
Unread post by rahtzir »
Interesting topic. Two years ago I also replaced the rear hydraulic pipe on my C5 X7 HDi 2.0. I bought this pipe from a craftsman as well; he manufactures them himself on a machine. During use, I have not encountered any problems.
In addition, I do not use LDS hydraulic fluid because of its very high price. Instead, I use hydraulic fluid intended for construction machinery. The condition is that its viscosity and other parameters must be close to the original fluid.
I have also been driving with this fluid for two years. The car has been used in temperatures from -35°C to +42°C. I have also made long-distance trips, driving 8 to 12 hours a day for three days, including a trip to the Black Sea. Everything has been trouble-free.
I will add photos and the description from our local craftsman, but please do not consider this advertising, as I am not providing any contact details. My message is aimed at reducing doubts and fears about using non-factory-made parts, assemblies, or fluids for a car in situations where the original parts are unavailable or excessively expensive, provided that they are not critical to safety.
One of the key conditions for such “replacements” is understanding how the part or system works.
Advert text:
“These pipes are also suitable for regions where temperatures below -30°C are common. This is an exclusive solution: a special Italian hose that does not harden down to -55°C and does not crack in extreme temperatures.
Before buying from other sellers, ask them what you should do if the old seal, the metal-rubber washer, starts leaking. Citroën does not sell these washers separately, and it is impossible to order them. Your used washer has already been compressed, and it can also be damaged during removal, especially if the nut is stuck and has to be heated with a torch. Also ask how the NBR rubber ring used in their pipes differs from the green fluoroelastomer seal used in the original pipe.
I designed this pipe with the possibility of a conical seal using a copper sleeve. This is only possible thanks to ultra-precise manufacturing of the fitting, accurate to one hundredth of a millimeter, on a Swiss Schaublin lathe, while maintaining the required cone angle.
In other words, if your old factory seal starts leaking, the kit includes a special washer. By replacing it, you solve the problem.
The pipe fittings are machined from stainless steel with a wall thickness of 3 mm. The connection accuracy to the hydraulic strut is 0.01 mm, which is one hundredth of a millimeter. The high-pressure hydraulic hose is a high-quality Italian hose, and all sealing rings are made of fluoroelastomer.
The pipes come with a one-year warranty and installation instructions.
I have been working as a hydraulic specialist at a Citroën service center for more than 10 years. I also own a 2002 Citroën C5 and a 2009 Citroën C6. This pipe is made by a hydraulic specialist.”
For quick communication, you can contact me on Telegram: @rahtzir
