- x 8145
Re: Citrojim's AX, Saxo, Pixo, Running and Cycling Tales
Got a nasty feeling that Daffodil's pet may have stolen its coat from her synchromesh rings!! Hopefully it won't become an issue
- x 8422
Happily the gearbox is as smooth as silk Mickmickthemaverick wrote: 27 Dec 2020, 17:52 Got a nasty feeling that Daffodil's pet may have stolen its coat from her synchromesh rings!! Hopefully it won't become an issue![]()
Michel
“ Tomorrow I'll be doing the wheel bearings... Currently the bearing housings and circlips are soaking in Plus Gas..”
Some good work there Jim! Maybe I’ll get to see it before the end of time
What is in Plus Gas? To me, it smells and feels like diesel, which I’ve used to similar effect in the past.
Skull
- (Donor 2026)
- x 382
CitroJim wrote: 27 Dec 2020, 17:34
I'm delighted at Daffodils overall condition, she's very clean underneath and so far, I've found nothing during my activities on her to give me any concern![]()
Gary
Gary
- x 5674
They are being very limited in their descriptionMichel wrote: 27 Dec 2020, 20:45 What is in Plus Gas? To me, it smells and feels like diesel, which I’ve used to similar effect in the past.
https://www.arco.co.uk/103/content/fact ... ricant.pdf
- x 8422
Mike, I'll be delighted to see you as soon as the current situation allowsMichel wrote: 27 Dec 2020, 20:45 Some good work there Jim! Maybe I’ll get to see it before the end of time![]()
Plus Gas certainly smells like diesel but is a lot thinner, It reminds me a bit of Tractor Vaporising Oil (TVO), a high grade of paraffin (kerosene). All I know is that it does a cracking job
Interesting to see the MDS for it Steve, thanks for posting that
I've seen what happens if an aerosol propelled by butane is sprayed on a hot surface
The bang and fireworks were most impressive... Remarkably, the printer survived!
Michel
The Shell spec sheet for that particular distillate is ..
https://www.shell.com/business-customer ... 042016.pdf
So Jim is right, it’s a light paraffin.
- x 8422
A very nice man from Amazon brought me this today
A vacuum brake bleeding kit... I'll be trying it on Daffodil later
It should make flushing out her old brake fluid and bleeding in the new a nice, clean and easy job.
I'll report back
Just waiting on a delivery of brake fluid now...
I'll report back
- x 5674
Sure it's not a Covid test kit?
- x 8145
Came across this site Jim in my meanderings and thought you'd find it interesting if you haven't come across it before:
http://www.gifarmer.com/bike.shtml
- x 8422
If the pressure gauge goes into the red you're positive
Mick, thanksmickthemaverick wrote: 28 Dec 2020, 12:06 Came across this site Jim in my meanderings and thought you'd find it interesting if you haven't come across it before:
But first, now I've done all my domestic stuff, including cooking a wicked curry
- x 8422
Over the years I've replaced countless wheel bearings, mainly in Xantias and XMs and in every case they've been a fight
Even a little Pug 106 I did put up a very credible fight!
I was amazed today at just how easy Daffodil's were to do... I got an idea they would not be difficult when I was able to extract the circlips without mangling them and attacking them with a cold chisel and big hammer
The bearings needed very little pressing out...
Normally, to get the inner race off the stub axle takes heat, angle grinders and cold chisels but not Daffodil's... Hers came off using a flat bearing puller and a pair of big tyre levers
And here are all the removed bits, all undamaged, ready or new bearings to be fitted... That's a job for tomorrow...
The old bearings had died for the usual reason...The grease had dried out...
Reassembly will commence tomorrow, weather permitting
I'm hoping by tomorrow afternoon Daffodil will be back in her warm, dry garage...
Then it'll be time to do the rear drums and bearings... I can do those indoors...
- x 8422
A very good day on Daffodil today...
After spending the night in the freezer to shrink them, the new bearings and the hubs/stub axles slid into place a treat
Reassembly did not take long
Behind the shiny new disc, bearing and pad is a nice new driveshaft
Wheels on and Daffodil is nicely tucked up in her cosy garage again
The remaining jobs can now be done indoors...
I gave my new vacuum bleeding kit a try today...
Fundamentally, it works well and is great for drawing a large volume of fluid through the system for flushing purposes.
One problem I was warned about by a person with much experience of these things is that they have a tendency to draw in air down the bleed nipple threads and this can be seen as a stream of small bubbles in the fluid flowing out of the nipple.
This does not seem to have adverse effects on braking performance but just in case I'll likely use it for an initial 'quick and dirty' bleed and a flush before doing a final bleed using more traditional methods...
It certainly does make it a very quick and clean job of it... The waste fluid catch bottle is a lot better than the jamjar used in the traditional methods... I have a terrible tendency for kicking over jamjars full of brake fluid and making a terrible mess
- x 5674
I thought that that was compulsory!CitroJim wrote: 29 Dec 2020, 17:39 It certainly does make it a very quick and clean job of it... The waste fluid catch bottle is a lot better than the jamjar used in the traditional methods... I have a terrible tendency for kicking over jamjars full of brake fluid and making a terrible mess![]()
- x 8422
It certainly is in my case Stevemyglaren wrote: 29 Dec 2020, 18:40I thought that that was compulsory!CitroJim wrote: 29 Dec 2020, 17:39 It certainly does make it a very quick and clean job of it... The waste fluid catch bottle is a lot better than the jamjar used in the traditional methods... I have a terrible tendency for kicking over jamjars full of brake fluid and making a terrible mess![]()
