I am an Activaist-v6 and a 2.1Estateerr
wurlycorner
- x 271
Re: I am an Activa owner...a V6 and I am an addict
Or it's cause I managed to make a double post (2 posts of the same stuff, cause I had had quote instead of edit) hence then editing out the second post (no option to delete it)...
Iain
CX DTR T2 Safari (silver)
Iain
daviemck2006
- x 485
And that was self abuse too. I think we need the men in the white coats [emoji12] [emoji13] [emoji3]
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 2006
- x 2006
Throttle body enlargement and port matching under way.
Throttle body to Inlet chambers, note the large mismatch which is causing me a little head scratching at the moment. I cannot get an image (in my head) of what I can do with the throat mismatch [bottom left], I may have to get it re pinned.
Note the generally good surface except in the inlet area and the chamber splitter [or whatever it is called].
I with smooth to that area only and knife edge the splitter.
Any thoughts on the "bulge" on the side of the inlet chamber and why it is there ? [Note: shown at Top of the image, it also has a cosponsoring "cut out" on the outside]
Skull
- (Donor 2026)
- x 382
Good effort Stickyfingers
I remember years ago getting my bike gas-flowed by a well known 'tuner' and matched to a Yoshimura exhaust with 'power chambers' ..cost a fortune at the time .... it never ran as well after and on further investigation they had fitted the standard size exhaust gaskets which were now effectively restrictors and the 'power chambers' had just been cut off and welded up
Tried to claim costs back but company had already phoenix-ed into the same company
Gary
Gary
Skull
- (Donor 2026)
- x 382
Gary
Gary
- x 2006
Interestingly, the gasket is @70mm and the throttle body at 65mm.....the inlet chamber throat is between the two.
I do not really think gas flowing makes much difference and polishing I think degrades the turbulence within the chamber. I will just match the sizes, clean up edges and flash a bit but leave everything rough. The exception to that will be the inlet side of the throttle body which will be polished
Skull wrote:Good effort Stickyfingers
I remember years ago getting my bike gas-flowed by a well known 'tuner' and matched to a Yoshimura exhaust with 'power chambers' ..cost a fortune at the time .... it never ran as well after and on further investigation they had fitted the standard size exhaust gaskets which were now effectively restrictors and the 'power chambers' had just been cut off and welded up![]()
- x 2006
First rough cut.....
Before
Before
- x 2006
A good fit on the other end......
Only a little work needed here.....
- x 2006
Well One port done ....but COLD (-7 tonight and a metal roof) stops play despite the wood burner glowing
- x 8437
Now you know why the old railwaymen used to call your part of the world 'Siberia' AlasdairStickyfinger wrote:but COLD (-7 tonight and a metal roof) stops play despite the wood burner glowing
Good work though, I'll check my throttle body today, not been in my workshop for days and days now...
- x 2006
Burrrrrrrrrrrrrrrr morning .....cheers Jim.
Talking about cold.....a guy I know just finished this
- x 8437
- x 2006
The guys is a star at action sculpting....his ground work however is stunning on this.
- x 2006
Every time its cold I seem to just mess about
