C5 X7: JWS 3309 vs. JWS 3324
Xantippa
- x 29
Re: C5 X7: JWS 3309 vs. JWS 3324
I´ve had JWS 3309 on my Euro5 car now for 5 years and over 100000km, no problems. Trying to get oil changed before spring though.
- x 6946
Marko, with respect, that may be the case, but it is NOT what is officially stated and we want to provide as much Factual information to members as we can and this does not help.
PSA specifically state:
CAUTION: The oil type "AW-1" in AT6 and AM6 gearboxes with engine version Euro 5 is specific and cannot be replaced with oil type ""JWS 3309"".
Xantippa
- x 29
Yup. Because of Euro 5, not because it wouldn´t work just fine. Maybe fuel consumption is a bit higher with thicker JWS3309, but in the other hand that oil lubricates transimission better.
ChugunOK
Hi everyone, this topic on this forum is probably the most informative about the difference between JWS 3324 and JWS3309, sincere thanks to all the contributors!
Marc, could you please confirm via my VIN which would be the correct oil spec for my gearbox according to Citroen specification(JWS 3324 or 3309)? I guess my car has an Euro 5 compilant Gearbox AM6-2 since it is classified Euro5 and was produced in 2014.
Thanks and best regards,
Mikalai
Mikalai
- x 6946
Hi Mikalai.
Ok, so you have a Euro 5 vehicle, therefore you need to use the JWS 3324 oil (or equivalent PSA specification) for the Euro 5 variants of the AM6 gearbox.
ChugunOK
Thanks a lot, Marc!
primariumm
Hello
Please if could someome check tipe of oil to be fitted in my gearbox. It is c8 2010 euro5, but i am not sure is it 3309 or 3324. Filling plug on gearbox is painted rose color and written "aw1". I am little confused because gearboxes from 2011 are fitted with 3342 oil and my car is 2010. Previous oil was red color. I have flushed gesrbox with Liqui Moly ath 1800. Color of that oil is brownish.
To cut the story short my vin is
I realy appriciate your afford checking data.
Thank you in advance.
- x 6946
You require JWS 3324, as your vehicle is a Euro 5 standard.
tatiana
Hi! Would you please help me to identify which standard does my car meet, Euro 4 or Euro 5, and, consequently, which of these oils should I use?
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Thanks a lot in advance! I have no idea how to find it out on my own...
- x 6946
@tatiana: You have a Euro 4 vehicle, so require JWS 3309.
tatiana
Thanks a lot for your prompt answer! This forum is of great help for car owners. I'd spend about 4 hours trying to get any idea what oil to use before I found it, and felt totally confused.
You're the best!
Jjbb
Hi Marc, I'm new here so first want to say Hello to everyone.
Could you please help me decoding my VIN to check which gearbox oil is best for my car?
Thank you so much in advance.
- x 6946
@Jjbb: Hi and welcome.
Your vehicle is Euro 5, so requires JWS 3324
Jjbb
Hi, many thanks for your quick response, I did check the code on gearbox and I got AW BVA AT6, I assumed it was Euro 5 but just wanted to make sure.
- x 6946
I've checked from your VIN, so correct as it left the factory.
