c5 suspension woes
- x 1994
Re: c5 suspension woes
I think by the sound of it, it has been done by moving the roll bar clamps and a Mk1 Eye Ball.
aeroboy64
Its not 100% fixed yet but on the test drive was the difference between night and day?My mechanic only tried adjusting the height sensors manually just to see if it made a difference and by golly what a difference it made but still needs to be calibrated with lexia but we now know that we are moving in the right direction (smoothly i might add).GiveMeABreak wrote:I've located all the X7 suspension measuring Docs now - but as you seem to have it working to your delight, I won't bother transferring these now unless anybody else wants them. Glad you're happy - it would be interesting for you to post back what the measurements were that he programmed into your car if you get time.
aeroboy64
and a certain amount of common sense.Stickyfinger wrote:I think by the sound of it, it has been done by moving the roll bar clamps and a Mk1 Eye Ball.
- x 1939
From reading the post I reckon he just set it up by eye (and maybe a tape measure) by rotating the clamp on the AR bar. No Lexia/Diagbox needed for that! That's actually the same method I used for my Phase I C5 when the dogleg ball joint on the rear pot rusted off. I had tried to use the Lexia to set the height properly but it didn't seem to respond as I would expect and eventually decided "soddit" and started adjusting the clamp slightly until the car looked right.GiveMeABreak wrote:I've located all the X7 suspension measuring Docs now - but as you seem to have it working to your delight, I won't bother transferring these now unless anybody else wants them. Glad you're happy - it would be interesting for you to post back what the measurements were that he programmed into your car if you get time.
Sometimes trying to do the right thing just doesn't bear fruit!
EDIT - a bit late to the party with my thoughts there!
WRT the X7 docs; as a recent owner I might be interested in them please.
- x 1994
4 sureaeroboy64 wrote:and a certain amount of common sense.Stickyfinger wrote:I think by the sound of it, it has been done by moving the roll bar clamps and a Mk1 Eye Ball.
- x 6945
Send me a PM with an email Paul and I'll send the PDFs I have so farPaul-R wrote: EDIT - a bit late to the party with my thoughts there!
