It looks like this query has come up before;
http://www.frenchcarforum.co.uk/forum/v ... 27&start=0" onclick="window.open(this.href);return false;
C5 4HP20
- x 3296
Re: C5 4HP20
pavlebo
- x 8406
Re: C5 4HP20
Give the area a really good clean-up and then the source of the leak should be revealed...
Hope it's not the valve block cover seal...
pavlebo
- x 8406
Re: C5 4HP20
I see you have borrowed one of my pictures there
A leak there suggests the torque converter neck seal may have failed...
That is bad news as it means removing the gearbox to replace it
I hope it is not that seal
Removing the 'half moon' plate on the bottom of the gearbox bellhousing may make diagnosis a little easier...
pavlebo
- x 8406
Re: C5 4HP20
And it is definitely ATF and not engine oil?
The seal should be available from any good ZF spares agents. In the UK http://www.automaticchoice.co.uk" onclick="window.open(this.href);return false; will be able to advise and supply...
pavlebo
Re: C5 4HP20
I really don't know.
Before changing gearbox there has never been traces of oil.
Someone wrote that ATF oil has strong smell, but this does not?
And color of oil under gearbox is not so black as motor oil, as you can see on the picture.
Gearbox is second hand, and perhaps has long be out of use, and o-ring harden and leak.
My fault that I did not immediately changed, but it is the fate of the owner Citroën in Montenegro, no spare parts.
I am gonna to dismantle gearbox again and I find out, and I do it as part of my hobby and I do not mind.
Do you have oil ring part number?
Thank you for providing the requested information.
pavlebo
Re: C5 4HP20
O'ring part number : ZF 0734310316
1997V6
Re: C5 4HP20
I received the following reply from ZF Services UK Ltd, Technical Support, to my question about their 4HP20 gearbox:citroenxm wrote:Yes it sounds like the box has expired and will need replacment or rebuild.. Had it ever had a Fluid change at all?
What sort of miles,? Which engine petrol or diesel? Diesel 2.0 hdi use AL4 and 2.2 HDi use the HP4 20.
ZF claim a sealed for life gearbox, but none are really. A fluid change always helps a gearbox work for longer.
"Your 4HP20 transmission takes ZF Lifeguradfluid5. Although the gearbox is "filled for life" we recommend an oil change at 60,000 miles. I have attached an oil specification sheet and a list of our aftermarket car parts centres where you can buy genuine oil and service parts for your transmission. To prevent damage and premature transmission failure you should only use the specified ZF oil in your gearbox."
- x 8406
Re: C5 4HP20
Precisely and always what we say on here...1997V6 wrote:To prevent damage and premature transmission failure you should only use the specified ZF oil in your gearbox."
Now from the horse's mouth as it were...
pavlebo
Re: C5 4HP20
Some mechanic here told me that I can not change only oil seal,
that I must change oil pump and repaired converter?
If it is true, that is too expensive and I will stop fixing gearbox/C5!
- x 8406
Re: C5 4HP20
It is common sense to have the converter overhauled whist it is out. To not do so risks trouble later..pavlebo wrote:Some mechanic here told me that I can not change only oil seal,
The oil pump should be ok, it all depends if what has caused the seal to fail has caused any further damage as the converter neck bearing sits in the oil pump housing and if this bearing seized it spins in its housing and indirectly damages the oil pump...
lexi
- x 133
Re: C5 4HP20
Jim: Have you ever seen the main clutches wear in the 4hp20? Not the lock up in the TC. I think there are another two clutch packs,maybe forward and reverse..........A and B?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
