Oops sorry about that, I've been suffering from Danielle's cold for the past couple of dayscitroenxm wrote:Ah jim... Only managed to get home.. Today i have the most awfull stinkey cold in nose and head and feel absolutley crap!
Paul
S2 Xantia V6 - Apologies in Advance
Xaccers
- x 188
DIY sphere tool
DIY sphere tool
gadgetgricey
Paul,citroenxm wrote:Have you press the horn in the car and listened for a click??
Ive no idea where it is... the only problem I had on an S2 once was the multi switch behind the steering wheel that also carries the Air Bag signal and radio controls button signals..
Sorry Dave, I cant be more usefull.... just useless..
Paul
Dont be daft, you and Jim have been my saviours in this thread. And there are still about three or four things to sort out after this one.
Time for stupid question number five..... Would the horn/horn relay work with the engine off??
Also just found the following from an earlier FCF thread.
Will hopefully sort this tomorrow, then its just the temp sender unit, electric rear windows/sunroof.rdj104 wrote:Coming back with the answer on this one, for future reference for others.
I fixed my horn problem, turned out it was one of the connectors near the steering wheel that had been savaged, some soldering iron work fixed it.
But anyway, yes my Xantia does have a relay for the horn, as I suspect must have all mk2 xantias, not because there is (or is not) a compressor to activate, but because sending all the current for the horn up a little ribbon cable to the steering wheel just makes no sense.
There are a load of relays down in the driver's footwell, you have to unclip some of the carpet to get to them. There you will see various random relays and 3 or 4 green ones in a line. I have 2 exclusives Hdi's, one has 4 relays, the later one has just 3, and a gap for one (ie no relay base) near the door.
The relay in question is in the second hole, working from door to centre of car, on the 3 relay car, the one closest to door, on 4 relay car 2nd one from door.
To test the horn, use a jumper to connect the terminal at front side of car, to one at the back side. The 2 terminals to the sides are the trigger to the relay that come from the steering wheel.
Hope this helps someone in the future.
Cheers all.
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
- x 8437
gadgetgricey
Yes, I did have a look but it made my brain hurt thinking of my Physics lessons 20+ years ago.CitroJim wrote:Dave, the horn will work with the ignition off. Look at my diagrams and you'll see it's powered via F7 independent of the ignition switch.
Probably reading it totally wrong, but is 2505 a relay. Because of the 12V live feed, just wondered if the relay is stuck "on".
But then the radio control buttons, all seem to be going via that route as well, and they al work fine??
Thanks again
- Dave -
- x 8437
Hi Dave,
Yes, 2505 is the relay. It switches the 12V to the horns. The location diagram shows where the relayt is located and if you press the horn button you should hear the relay click. If you hear it click but cannot locate which one it is, try touching kit as you'll feel it click too..
Chances are, if the radio controls work and the airbag lights are correctly extinguised, the rotary coupler is good.
You can do tests at the realy base by unplugging it and using a test meter on the realy base socket...
The relay can be tested by swapping it with a same-coloured one. Your scrapper 2.1 should be able to provide one...
citroenxm
- Fallen Hero
- x 70
Xac wrote:Oops sorry about that, I've been suffering from Danielle's cold for the past couple of dayscitroenxm wrote:Ah jim... Only managed to get home.. Today i have the most awfull stinkey cold in nose and head and feel absolutley crap!
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8437
citroenxm
- Fallen Hero
- x 70
gadgetgricey
I think the car hates me.
Just had 30 mins, so popped out to have a look for the horn relay and do a couple of other things.
Thought the relay was in the drivers footwell, so pulled all the carpet back and then realised its "under" the dashboard, above the standard fuses.
Put the carpet back and then tried to have a look at the relays, no clicking on any of them but a real git to get to let alone have a look at.
Will carry on with that tomorrow.......
Then fitted the drivers sun visor, and refitted the heater controls as they were skew wiff. All done, couple more things ticked off the list
But then
Realised the electric seats no longer move and the blower has stopped working.
These things are sent to try us, but got the distinct feeling of one step forwards, two steps back today.
More details tomorrow.
Cheers
- Dave -
But then
Cheers
- Dave -
gadgetgricey
AAArrrgghhh... Help
Well had a look tonight to try and figure out why the blower and seats no longer work.
Retraced what I had a look at yesterday, and found this "additional" relay connected/hanging. On closer inspection two of the connections have come loose.
Recrimped them and thought "what's the worse that could happen"?? Well the worse that could happen is blow the electrics.
Still got 12V, as the alarm and central locking work, and one of the wires has a 12V feed. But not getting any dashboard lights at all (other than door open symbol)
Key In, Turned dont even get battery light on dash, let alone anything else. Have I fried the ECU???, or is there another fuse relay that can take the whole system down. I was thinking Alarm, but that still works..
Any advice/pointers would be warmly received as always..... as I dont even know what this is let alone how to fix the damage I have caused.
Did not even take the one step forward today, just the two steps back..
Thanks again
- Dave -
Thanks again
- Dave -
citroenxm
- Fallen Hero
- x 70
That looks more an After Market Mod relay thats been fitted... as all the wires look red to me....
Check the LARGE fuses in the fuse box behind the battery dave.. they are the Main supply fuses...you cannot miss them..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citrov6
citroenxm
- Fallen Hero
- x 70
gadgetgricey
She lives,,,citroenxm wrote: Check the LARGE fuses in the fuse box behind the battery dave.. they are the Main supply fuses...you cannot miss them..
Paul
Cheers Paul, Managed to blow the 60A one.
Going to try and chase the wires back at some point. Just wondered if they had run the feed for the relay, off the power seats/blower circuit.
hence why they both stopped working.
For the moment though, just going to tape them up and try and concentrate on the horn.
Thanks again,
- Dave -
gadgetgricey
Going to have another look at this the weekend, if I get the chance.
However bound to be some Car boot sales or something that SWMBO wants to go to...
As per previous updates, I've now lost power to the fan motor and electric seats. Checked the fuses for both and they were not blown.
Just wondered if there were any relays for these as well, and if so where??
(Need to try and get the seats working at least, 'cos cant easily get to the relays under the dash for the horn issue with the position the seat is currently in)
Thanks again
- Dave -
Thanks again
- Dave -
