Any CX experts faimiliar with the MK2's out there?
SwissSPEC
CGATCX25GTITURBO
- x 16
I used to have threeSwissSPEC wrote:Are you allowed to have 2 maikonics cars![]()
There are ways around the Maikonics
What I'm not sure about is the Cat equiped AEI versions
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Citroening
- x 19
...do you know what happened to that car Neil - still around or a long time ago?CGATCX25GTITURBO wrote:I used to have threelhd series 1
Not many Maikonics cars left and it's nice to keep track of them...apart from the below do you know of any others left?
GTi Turbo 1 Series 1 - Seen at last CXM Rally - Intercooler too.
GTi Turbo 1 1/2 - in OZ.
GTi Turbo 1 1/2 - CGAT - Yours
Prestige Turbo Series 1 - Fils
Prestige Turbo 2 - One of 5 RHD Prestige Turbos.
GTi Turbo 2 - Mine
GTi Turbo 2 - FBAT - Scotland
GTi Turbo 2 - White - G530 XDP.
Franklin
CGATCX25GTITURBO
- x 16
Only mine left of the three
Fbat had it's AEI alien autopsied to see what made it tick and was (-expletive removed-) up in the process I believe
an electronics engineer couldn't fathom what it did and declared the conversions as a err hoax..
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Citroening
- x 19
...you're the second person Neil to say that about FBAT's AEi as a chap that was looking for a Maikonics Kit for his Turbo 2 who enquired about one that my dad had for sale (the one that's now on G530 XDP), said it was no good.
Strange though that I was told that it was "all ok" by the owner when I enquired about it last October..
...who knows?!, yes to AEi , and wastegate- I have opened up AEi to confirm and also to test delay for nos
Franklin
CGATCX25GTITURBO
- x 16
I doCitroening wrote:...you're the second person Neil to say that about FBAT's AEi as a chap that was looking for a Maikonics Kit for his Turbo 2 who enquired about one that my dad had for sale (the one that's now on G530 XDP), said it was no good.
...who knows?!
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Citroening
- x 19
SwissSPEC
Anyone got any tips on changing the gearbox oil (its a manual)?
I'd also be grateful if someone could tell me what oil specification i need & how many litres & how often does it need doing? If the car hasn't been used much, does it still degrade & so its still worth doing a change or not?
Cheers
Cheers
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Bx Gti 16v
BX TZD Turbo - Sorn
andmcit
- x 30
A reminder check throws up an official Cit manual reccommendation of
TOTAL EP SAE 80 W/85 W - total capacity of 1.7 litres with a capacity
after draining of 1.6 litres. Difference between min / max on dipstick
0.150 litre (1/4 pt).
Personally, I'd concentrate on the engine oil and leave the gearbox alone!
These may be a bit rough'n ready but rarely give trouble, are a sealed
circuit (unlike Xm, Xant etc which have wet driveshafts) and are built like
the proverbial brick 'outhouse'.
I'd expect the oil to be fine but checking the level is a bit hit or miss so
something you could do in your ownership of the car. If it selects Ok and
doesn't whine, I'd just consider it after other more important things like the
spheres, exhaust, oil and filter, handbrake (inevitability) and rust
protection go first!!
Andrew
Andrew
SwissSPEC
SwissSPEC
If i need to get replacement tyres (its got the original Turbo alloys fitted) whereabouts can i buy these non standard types from, or is it more economical just to buy some modern replacement alloys instead with tyres, which will work out cheaper in the long run?
Bx Gti 16v
BX TZD Turbo - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
andmcit
- x 30
Are you sitting down?
http://www.vintagetyres.com/results.asp ... &m=1&dc=78
or 147/156 Alfa fitment:
http://shop.ebay.co.uk/i.html?_nkw=alfa ... m270.l1313
Andrew
Andrew
Citroening
- x 19
...the proper 210/55/390 Michelin tyres cost £250 per corner, so I doubt you'll be wanting them!SwissSPEC wrote:If i need to get replacement tyres (its got the original Turbo alloys fitted) whereabouts can i buy these non standard types from, or is it more economical just to buy some modern replacement alloys instead with tyres, which will work out cheaper in the long run?
You can get Alfa wheels that fit CXs, which have the more conventional tyres - you can opt for the 15/16 or even 17 inch ones too.
Watch out for the width of them though, as if they're extra wide then some modification is needed to the inner arches.
...also, if you keep the standard T-slot wheels, you'll no doubt have to get them refurbed due to standing.
Franklin
andmcit
- x 30
CGATCX25GTITURBO
- x 16
