Tyres
Citroenmad
x 110
Re: Tyres
Unread post by Citroenmad »
Toyo R1-Rs, even I had to google those :lol:
I like Toyos and I have always gotten on very well with the T1-Rs, I thought a superb tyre, wears quick but they grip very well and they are cheap so I dont mind having to replace them more often. I notice they are available in 205.55.15 size but not standard Activa 60 profile. Though the T1-Rs seem to get mixed reviews, they obviously suited my car and driving style. Only thing I could fault them for was heavy wear on the outside tyre shoulders, my C5 balded the edges much sooner than the rest of the tyre, tracking was spot on.
CF-1s are ok, ive had them on a few cars and found them to be fairly good for the price, dry grip I found good but wet could have been slightly better, not bad though. These are the only Toyos available in the Activas standard size.
Those R1-Rs get excellent reviews:
http://www.tyrereviews.co.uk/Tyre/Toyo/R1R.htm" onclick="window.open(this.href);return false;
Ive not even seen them before, I imagine they will suit an Activa a treat :-D
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Sl4yer
Re: Tyres
Unread post by Sl4yer »
Citroenmad wrote:Do you run the same pressue front and rear Sl4yer?
Yes, I usually go for 38psi all round. Looks like there is a Sportrac 5 out now.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
bxzx16v
x 34
Re: Tyres
Unread post by bxzx16v »
I've got a set of T1 r's on the Zx , not a bad tyre at all for the money . It doesn't do much mileage so wear isn't an issue really .
Mark
XantiaMan
x 18
Re: Tyres
Unread post by XantiaMan »
I dont rate the Toyo T1-R, i had them on my Maestro and they were useless even when new, i've also got them on the Fiesta, originally on the back but i put them on the front after the rear stepped out in the wet, i now have Michelin PE2's on the back and its like glue, downside is i now have chronic understeer on roundabouts and third gear wheels spin, its a 1.6 FFS. Avoid, old tech tyre thats cheap for a reason now and times have moved on rapidly on tyre development.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
Deanxm
x 87
Re: Tyres
Unread post by Deanxm »
I wouldnt say that at all Gareth, they are a fairly soft compound and dry grip is very good with a high rate of wear, i would say about average in the wet, its testimony like this that makes me wonder how consistant tyre quality is within certain brands.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
XantiaMan
x 18
Re: Tyres
Deanxm wrote:I wouldnt say that at all Gareth, they are a fairly soft compound and dry grip is very good with a high rate of wear, i would say about average in the wet, its testimony like this that makes me wonder how consistant tyre quality is within certain brands.
D
Maybe the higher profiles are more forgiving, i'm basing my experience on a 50 profile. Dry grip is fine, wet grip is barely above a budget tyre. I know alot of racers use them because they are so soft but this doesnt always make a good road tyre. More recently Bridgestone has impressed me for its all round grip, i had them on the Puma, even the fronts down to 3mm were better than my Toyos at 6mm. I'll only be buying Michelin or Hankook from now on for all my vehicles, false economy in the long run and you'll only kick yourself for buying something that doesnt perform all round, spoils the fun of driving completely.
2017 Fiesta ST
x 8422
Re: Tyres
I've got to replace all the tyres on my Activa very shortly. I've not worn them out but they've deteriorated through old-age.
Given you all know how I drive and that my Activa see very little real use, give me a recommendation please :)
Thanks!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Err... Solid oak? :P
Citroenmad
x 110
Re: Tyres
I thought my T1-Rs were decent, I got a new set during the snow a few years ago and they pulled my C5 around where other cars were getting stuck in deep snow. Quite surprising, though I guess the V tread design helped to grip the snow. I also liked them in the wet but they were excellent in the dry. My C5s current Michelin Primacys are better in the wet, but they are £145 each vs the Toyo £110.
I wouldn't have the CF-1s on the Activa though, I want the best possible and they are not quite it. There is no point in having an Activa if its on plastic tyres, as you can't use the cars abilities, especially in the wet.
I would say that Uniroyal RainsportIIs are a much better performing tyre than the T1-Rs, wet grip is superb and wear rate is better. Dry grip is good, not the best but grip does not drop off on wet roads ...
I always like to stick to Michelins Gareth, all our cars have Michelins fitted to at least the front wheels, mostly all fours. But the energy savers are not tyres for an Activa, too soft on the sidewalls for one thing. I might well try some Hankooks, they are a tempting price and get decent reviews, a shame the Evo 2 is not in the Xants size, but it is in the C5s size. Saying that, there are many decent tyres available for my C5.
I think I'll go with the Vredesteins when I replace the Activas tyres, doubt that will be long as its current fronts are looking aged and have awful wet weather grip. Mind, I try not to use it in the rain :lol:
CitroJim wrote:I've got to replace all the tyres on my Activa very shortly. I've not worn them out but they've deteriorated through old-age.
Thanks!
These are the ones im going for:
Can be bought from here. :-D
Jim, I think you would do very well to fit the Vredesteins which im thinking about. They look great, are priced well, get excellent reviews and perform well in the wet too. Whats more I got a pair for an XM about 5/6 years ago and they are still on the back of the XM estate now, looking like new with no age cracks appearing, bearly worn at all and grip has not dropped off either.
03 Seat Arosa 1.0S
x 8422
Re: Tyres
addo wrote:Err... Solid oak? :P
:lol: I'd be worried about wood-worm Adam. Termites to you!
Citroenmad wrote: Jim, I think you would do very well to fit the Vredesteins which im thinking about.
Thanks Chris :-D They look the part and I like the price :wink: I've found the Contis that are currently fitted good but they are showing more cracks than our present government... Not sure how long they've been on either. All I know is they were on the car when I bought it and that was a few years ago now...
Deanxm
x 87
Re: Tyres
I was thinking about them but i cant get them in my size, might just get the xm's Perreli P zero nero's put on the back and get new Toyo's for the front as i want a bigger profile tyre on the Activa as gearing is too low as it is and i want to go for some new rubber all round on the xm, probably mitchelins, just got mitches all round on my comp car and as a day to day tyre they seem good.
D
XM Prestige PRV6 92
Citroenmad
x 110
Re: Tyres
CitroJim wrote: Thanks Chris :-D They look the part and I like the price :wink: I've found the Contis that are currently fitted good but they are showing more cracks than our present government... Not sure how long they've been on either. All I know is they were on the car when I bought it and that was a few years ago now...
Here is a review page on the Vredesteins Jim, they do appear to get good reports. :)
My other suggestion would be Uniroyal RainExperts. Again great reviews and the same price as the Vredesteins, Uniroyals are usually very good tyres.
I dont think its worth paying the price for a Conti, Michelin, Pirelli etc when the above tyres are well proven. :)
Dean, what is your company car?
I do like Michelins, they are usually good tyres, grip well and suit Citroens very well. Our XM has Michelins on the front and they are very well suited. My C5 has Michelin HPs, which are very good and even wear well too, given my driving. I can see me getting 20K from them.
03 Seat Arosa 1.0S
x 8422
Re: Tyres
Citroenmad wrote: Dean, what is your company car.
I thought at first you were speaking of a competition car Dean :roll: :lol:
x 8422
Re: Tyres
Citroenmad wrote: Here is a review page on the Vredesteins Jim, they do appear to get good reports. :)
I'll go with the Vredesteins Chris, the Uniroyals don't look as nice as the Vredesteins :) They'll be better on the V6 I reckon... So, four Vredesteins and two Uniroylas will be on order soon... The V6 got an advisory on her fronts for being perished...
Citroenmad
x 110
Re: Tyres
Excellent Jim, sounds like a very good match for both cars :) You'll no doubt be happy with them :-D
03 Seat Arosa 1.0S
