V6 Xantia......... the beginning of another adventure
- x 3306
Re: V6 Xantia......... the beginning of another adventure
Will do, but this is going to take some time.
KP
- x 27
Has Jim done this in the past with his actual lexia as if not Jim someone on here rings a bell for doing it in the past...
Trainman
- (Donor 2018)
- x 43
I think you could be right, actually, I seem to recall it now you mention it........KP wrote:Has Jim done this in the past with his actual lexia as if not Jim someone on here rings a bell for doing it in the past...
James there's no rush, I have to to the same...... whenever you've nothing to do, I've waited 12 months another month or 3 won't matter.... I do appreciate it though
Steve
http://c6owners.org/index.php
- x 3306
You have a PM with the main cable pinouts (I hope it makes sense!). I'll do the adaptor cable tomorrow.
Trainman
- (Donor 2018)
- x 43
Got it and replied. Thank you most kindly
Steve
KP
- x 27
Told you someone would have it! Just hope when I get my £5 Chinese one it works in my chixia without issue as it would be of some use on the xm..
- x 3306
The main cable is the one top right in this e-bay item. I will do the top left tomorrow (once I have found a couple of sewing pins!).
http://www.ebay.co.uk/itm/LEXIA-3-PEUGE ... 338d6e3c88" onclick="window.open(this.href);return false;
- x 3306
I have the cable, and a multimeter. Now I need a cuppa!KP wrote:Told you someone would have it! Just hope when I get my £5 Chinese one it works in my chixia without issue as it would be of some use on the xm..
- x 3306
I tried to pinout the adaptor cable, but I cannot be sure about the result (as my leads cannot go down the holes, so I was using sewing pins, and not getting consistent impedances). If I get clean results I will let you know.
Trainman
- (Donor 2018)
- x 43
Thanks James, had to take a step back.today as.one of the netbooks decided it wants a new hard-drive...... flaming thing.
I'm out tomorrow at a local transport show with the C6, so I will have a play on Monday.
Steve
KP
- x 27
What kind of drive does it use Steve as I may have a sore kicking around?
Trainman
- (Donor 2018)
- x 43
It's ok Will got one I already had, just got to put Windows on it......
Steve
- x 8391
I'd see the doctor about that Will...KP wrote:What kind of drive does it use Steve as I may have a sore kicking around?
KP
- x 27
Ha ha
I have a windows 7 USB install if you need a quick install sometime
Trainman
- (Donor 2018)
- x 43
I noticed that last night Jim, bless him, modern technology and he don't get along to well...... hehehe
Steve
