Zelandeth
x 1597
Re: Zel's Fleet Blog - Xantia Activa, BX, Jag XJ-S, Sinclair C5, Mercedes 208D, AC Model 70.
Unread post by Zelandeth »
Nothing much to report from this weekend, though I did finally get around to giving the Jag a wash this afternoon. The amount of gunk that was accumulated around the window seals and such like was frankly embarrassing.
It's definitely one of the most awkward cars I've ever had to clean - especially the front and rear overhangs. Doesn't scrub up too bad though from ten paces.
Hoping to get the van in for an MOT this week to find out if there's any work needed for that I'm not currently aware of (expecting a shock absorber and a couple of brake pipes as the ferrules are rustier than I'd like). Have had a couple of recommendations for a garage to use (my usual one can't deal with vehicles this large) so we'll see how that goes.
Current fleet:
x 8386
She's looking awesome Zel!
Zelandeth
x 1597
Later this week I've got a couple of portable split system air conditioners to collect. I reckon that I *might* just about be able to Tetris both of them into the back of the Xantia...maybe. I'm quite braced for having to make two trips though. At the end of the day it's only an hour each way so if I need to make to trips it's hardly the end of the world. However if I had the van available that would make things far, far easier as I'd have bags of room to spare then.
Following a few recommendations on the MK Modern Classics group on Facebook, I've got it booked in with MOTest in Newport Pagnell on Wednesday morning for a test. My usual garage can't do me an MOT on this as it's too big and too heavy for their test bay.
I've been out and given her a quick once over. The brake hose ferrules are a bit more crusty than I'd really like. I wouldn't say they're bad, but I'd definitely expect them to at the very least to be an advisory. They'll be getting changed either way - just not before Wednesday.
Still slightly irked that the garage last year didn't even get a mention last year given the number of as far as I can tell non existent faults with the braking system that they found and charged me for sorting...Would have expected the rigid lines to have got a mention too - though those at least just need a clean up I reckon.
The front shock absorbers, particularly the offside one look quite crusty (and it has a dust cover held on with a cable tie), but they both work as far as I can tell. Like the brake flexible lines, I'm going to plan on swapping those out in the near future anyway for peace of mind.
I've sorted the spurious brake pad wear warning light issue - by disconnecting the sensor leads. I'm not proud of it, but the problem is a simple fundamental issue with the system design which results in false triggering with modern brake pads. Rather than the way for instance BMC did where they just have a light in series with a metal tab in the brake shoe, which grounds the circuit through the disc when the pad gets worn down, Mercedes have the switching done by a transistor - meaning that even the tiniest bit of leakage to ground at the brake end of things brings the light on. I don't think I've ever actually seen one of these vans where the wiring wasn't snipped off decades ago... guessing this may be why! I've not cut anything, no need to. There are two connectors that can be unplugged in the engine bay. So if somewhere down the line I feel like modifying the system to be less hyper sensitive I can easily get it going again.
Discovered the nearside indicator repeater was out. This turned out to be a bit of poor design. The ground for the repeater is via the mounting screw - however that's just a self tapping screw into a plastic plug on the inside of the wing. A bit of rust on the screw where it passed through the wing = dead light. I've done away with that and replaced it with a nut and bolt with a shake proof washer, and a big blob of grease over it to keep water out.
There could be a thousand things I've missed though...it barely moved last year. Obviously being an old Merc rust is the biggest fear!
I then went and cleared what felt like about two tonnes of dead leaves and dog hair out of the interior.
I'll get back under there tomorrow and give all the rigid brake lines a rub down and see if I spot anything else needing attention. I will say it's really nice having a vehicle that you can comfortably work underneath without needing to faff about with jacks or ramps! In the interests of seeing off Murphy's Law, I do stick an axle stand under the chassis rails though just in case a spring decided to snap while I was crawling around under there. Unlikely? Yes. However I know my luck and it takes all of thirty seconds to do. So let's just play it safe.
I'd by absolutely lying through my teeth if I didn't say I that even just on the run to the testing centre that I was massively looking forward to driving the old bus again. It's been far, far too long. I do find it highly amusing the degree of decision paralysis that I sometimes suffer as to whether to go out driving in a Citroen Xantia Activa, 2.8 tonnes of camper van with 78bhp, a V12 Jag XJ-S, or an Invacar. I enjoy driving all of them...Though honestly the Invacar probably has caused the biggest grins from me lately.
They all have their moments though...
Xantia: Seeming ability to totally ignore the laws of physics where changes in direction are concerned and the addictive shove in the back when it comes on boost.
Jag: The sheer degree of torque from a standing start is absolutely ridiculous...oh, and the noise when you go anywhere north of 3000rpm. Comfort goes without saying...and the looks.
Van: She's just a lovely old thing to drive. Gearchange, steering, ride and strangely enough, the smell all say vintage bus to me.
Invacar: Hard to point at any one thing, as it's just such an utterly unique driving experience...and far, far more capable a vehicle than you'd ever think to look at.
In other fleet news, for the last month or so I've been unable to get the boot on the Xantia unlocked. Wouldn't unlock with the central locking or the key. No amount of fiddling around with either on a dozen or so occasions had any effect. Yeah...right up to this afternoon when I went outside to properly investigate and fix it.
When I unlocked the car to undertake this task the bootlid unlocked perfectly normally. The lock has then proceeded to work absolutely perfectly, and pulling the trim off didn't reveal anything amiss which would have caused any issues. Yep, that's pretty much situation normal then!
Current fleet:
x 1751
If like XM (?) there could be options for the angle the key is removed from the boot lock, which affects whether/not the central locking controls the boot. Owner's handbook should have details.
Zelandeth
x 1597
When it was playing up I couldn't open it with the key either. It would turn in the lock direction but not unlock.
The only thing I can think might have happened is if I accidentally activated the deadlocks (which I generally don't use), and it somehow stuck in that mode. Of course it then by completely random chance decided to unstick when I went to investigate...
Current fleet:
Zelandeth
x 1597
Had a few errands to run today, the weather was decent and as we weren't boxed in by school traffic for five minutes I took TPA out.
Another fifty or so miles done today without really thinking about it - even though I could have done without the monsoon that descended on the A5 about halfway home. She handled it fine though and about 90% of the water stayed outside the car, reckon it'll be fine once I replace the window channel rubbers.
The windscreen is at least fully weatherproof now it seems so I don't wind up with water dripping on my knees any more - that used to get old in a hurry.
Dynastart belts are squeaking a bit just now at idle but I reckon they'll shut up once they've bedded in a bit.
Current fleet:
x 8386
All the best with the 'Van MoT Zel and pleased to hear the Xantia boot is now playing nicely :D
Zelandeth
x 1597
Well that could have been worse.
One sticky brake caliper (41% imbalance on the machine - though it felt like it was improving on the way home) and a couple of silly minor things that will take five minutes to sort.
I've got it booked in for next Tuesday to have the brakes sorted - though if I have the opportunity before then I may well whip the wheel off and see if it will respond to a clean up and grease of the caliper slides.
Bit irked at the headlight aim...that was last touched by the previous test station and I always reckoned it was off since they fiddled with it. Though given the overall standard of their workmanship I shouldn't be surprised I guess...
Current fleet:
x 8386
That's not such a bad result Zel :D I'm sure the brakes will respond to a quite straightforward overhaul ;)
What's the machine at the top of the picture hiding the test certificate's sensitive details?
x 3306
Looks like a Psion keyboard to me.
Zelandeth
x 1597
CitroJim wrote: 28 Apr 2021, 17:04 That's not such a bad result Zel :D I'm sure the brakes will respond to a quite straightforward overhaul ;)
Let's hope so. If I can get it through the test without actually having to spend anything that would definitely be a bonus. I've still got a new set of brake pads sitting in the glove box from about a week after I bought it when I foolishly believed the pad wear warning light! So I'll probably throw those in while I'm there unless they still look like new. Not looking forward to that job...I don't like jacking any vehicles up at the best of times - but *particularly* dislike having the van off the ground! On the plus side, the jacking points are directly under the axles - so you only actually need to lift things about an inch.
The device you can see a bit of in that photo is one of several calculators here which is probably far cleverer than I am, a Texas Instruments TI-66 in this case.
Windscreen washers on the van have already been sorted - Hopefully they'll stay clear long enough to go through the retest...I had issues with slime growing in the washer bottle when I got the van which while dealt with means I still have a fairly regular issue with blocked washer jets.
I'd actually quite like to modify this to have washers on the wiper arms - as the screen is so tall and near vertical it's really difficult to get good washer coverage across the whole screen that does the job both when stationary and when on the motorway. With the jets as they're adjusted there you'll be lucky to get water halfway up the screen when travelling at any real speed.
While I was outside I also threw some paint on the exhaust on the Invacar as the overspray from the bodywork was really bugging me every time I saw it.
Anything else useful today was a bit of a write off as I had to run off to collect two portable air conditioners - portable splits though rather than the horrifically inefficient vented ones we currently have. These are surprisingly hard to find these days.
The bigger and slightly more modern looking of the two will probably go in the master bedroom.
The second one while slightly smaller and obviously older strikes me as being far more intelligently designed. If it works as well as hoped I may well be heading back to the seller for an additional one or two!
They should just be vastly, vastly more efficient than the vented ones as they keep the hot and cooled air completely separate - and you only need to have the window open a crack for the umbilical with the refrigerant lines in rather than about a foot for a huge vent duct. Be curious to see how well they perform.
I'd have liked to at least give them a good clean this evening...but after spending the best part of four hours stuck in a queue on the M25 I really wasn't up for being useful this evening!
Current fleet:
x 1751
Some of those single-unit portable AC's ought to be banned, especially as they can pull around 1kW.
Crazy that many of them push hot air out into the very space that they are supposed to be cooling, while at the same time working an an extractor fan on the very room air that has been cooled :gt: !
I have one in the workshop, which has been simply modified with two additional bits of 100mm hose, to eject hot air to outside, and bring in replacement air from ouside as well. The efficiency has leapt.
Zelandeth
x 1597
white exec wrote: 29 Apr 2021, 11:13 Some of those single-unit portable AC's ought to be banned, especially as they can pull around 1kW.
Yeah, they're horrifically inefficient. Why they couldn't just add a single additional 100mm hose for make up air for the condensing side of things I've no idea. It really wouldn't have added much to the manufacturing costs but would have vastly improved the efficacy of the units. Two of our old units are Amcor made and are very effective 10,000BTU capable...they do reject a huge amount of heat. Just sadly then on a warm day they then pull 75% of the warm air straight back in through the window!
These should be far, far more effective as the window only needs to be open a crack for the refrigerant lines to pass through...and there's no air being actively drawn back in as the evaporator and condenser have completely separate fans.
After a thorough clean and de-stickering session they're looking rather better.
The window ledge hooks have long, long gone for the outdoor units but they're dead easy to recreate.
I also reset the clock on the Mizushi as it showing 00:00.00 was driving my OCD mad.
We're never ever likely to use the programmer...but the clock being wrong was going to drive me round the twist. The one on the Seveso has equally been set properly now.
The seller has a shed full of these (they used to rent them out), and to be honest we're seriously considering going back for another couple of the little Seveso units with a view to actually selling on the existing vented ones come the summer. The Mizushi is far more modern (I reckon dating from around 2000), whereas the Seveso is from the early 90s, and we wanted a slightly less industrial looking thing for the master bedroom. Elsewhere though appearance is less of an issue, so I'd far rather use the older units as they're far better built and generally better thought out.
Current fleet:
Zelandeth
x 1597
Absolutely nothing to do with the cars this weekend - I'm absolutely wrecked now as it's been flat out yesterday cleaning and gardening today.
Turns out that the BBC want to do a brief segment (like a couple of minutes in one of their regional news shows) on the 40th anniversary of the Homeworld 81 Expo...And of course given that our house was built under contract to the then Money Programme, they want to get a bit of footage both from outside and looking into the house through a couple of the frontage windows.
This will be happening sometime over the next few weeks...Which means that a SERIOUS bit of tidying up needed to happen. Especially in the Atrium which has been basically buried for the last year and a half. With getting to the tip being a major hassle and charity shops not accepting donations, things have just slowly built up in there.
So over the weekend we started tidying it up. Took *all day* yesterday but it's mostly done now. Have had to recycle a lot of stuff we would normally have donated, but that's just how things have gone. Xantia is full again so will be doing another tip run on Monday, and a huge amount of stuff has just been chucked into the shed...I'll curse myself for that next time I need to get the mower out.
This does mean however that for I think the first time in at least a year and a half, we can actually see the pool table again!
Once that pile of stuff at the far end is cleared enough you can absolutely bet it'll be getting used again. Really do need to get the poor thing re-covered at some point though as the cloth is in really poor shape. Well, cosmetically it is - it actually plays astonishingly well all things considered. Just would be really nice to get it properly tidied up.
In the same vein, we got any graphical wizards here? One small cosmetic issue that really bugs me is that the original makers badge is really badly faded.
It's a small but quite prominent detail and really bugs me. The fact it's right in front of you when you come in the front door doesn't help.
The background should be black, the HGM logos and lettering frame white and the fill of the lettering a deep green. I *think* the "shadow" should be a 75% grey. Shouldn't be that hard to remake, but figured it was worth asking before I spend forever doing it the hard way.
Current fleet:
x 8110
We had a Superleague table in the club and when we needed to replace a cushion rail and cloth I emailed them with our needs and they supplied all we needed and were great to deal with. I'd suggest you email them with a pic of your nameplate and suspect they just might send you a new one. :)
http://www.hazelgrove-superleague.co.uk/
