ABS/ESR
Yarik
Re: ABS/ESR
Unread post by Yarik »
All ABS sensors are ok. Already checked. I’m interested in abs pinout to find the wire from break switch to abs.
x 6945
Re: ABS/ESR
Here you go:
Yarik
Re: ABS/ESR
Thanks for help.
So I finally found some time. Check all diagram check wires. Found 1 broken wire as ABS have 2 power wires from fuses. And wasn’t luck car won’t starts.
Than I start to check car configuration and found that settings are wrong. Change type of engine and gear box. And car start….
Now car starts but still are some mistakes U communication errors.
To be continue …
