Citrojim's V6 Conversion
Chris570
x 36
Re: Citrojim's Xantia, C1 and XM Tales
Unread post by Chris570 »
RichardW wrote:
KP wrote:Why not put the tct in the rear of the car and have a 10cylinder monster and ultra cornerig grip and forces ;)
Even Team WFA would be a couple of days on that job :mrgreen: =D>
How so!
easy done, get a tea urn on the go and a fire for bacon sarnies, be done before first light.
Probably best not to have a swear jar present though
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
x 8386
Chris570 wrote: Probably best not to have a swear jar present though
Swear jar? A job such as that is going to need a swear skip of at least 2yd capacity...
hattershaun
(Donor 2022)
x 4
Unread post by hattershaun »
For your Activa V6 you may wish to get an engine ECU, there's a specific one for the V6 engine with manual gearbox.
Bargain price direct from Bosch.
Here's the one I bought for my car.
https://boschelectronicservice.eu/uk/sp ... 0261206119" onclick="window.open(this.href);return false;
Best to cross reference with Citroen Service, just in case there is a difference S1 to S2 Xantia.
Shaun
C6 3.0 HDi Exclusive - 2010
SM 3.0 - 1972
DS 23 Pallas - 1975
GSA Pallas C-Matic - 1982
x 8386
That's excellent Shaun and thanks for that. I'll check and if good I'll get one...
KP
x 27
Unread post by KP »
Ooo that's Sir Jams next project in two years when he wants more grunt on the V6 :D
How does that work with the series 2 cph immob stuff? Isn't just a blank canvas so will pick up what's on the cph?
DHallworth
x 167
Unread post by DHallworth »
That's the same ECU I have in my Activa V6 as well.
It's dropped in price now too! It was €48, it's down to €33 now so a right bargain for a new, uncoded, unused ECU!
Only difference is Jim's car is an S1 so to keep the immobiliser alive he'd need an S1 ECU :(
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
KP
x 27
Unread post by KP »
Do you really need the immob on a series one or two though?
x 8386
KP wrote:Do you really need the immob on a series one or two though?
Not really. I'm tempted to get one and then have it properly unlocked so it'll be happy in an S1.
KP
x 27
Unread post by KP »
I would do Jim, most of us have rid ourselves of the keypad :) just wish I could :cry:
x 8386
Re: Citrojim's Xantia V6, C1 and Activa Tales
The first component needed for the conversion has arrived today....
The clutch kit..
We're on our way :-D
furriegurrie
x 40
Unread post by furriegurrie »
Just the parts that wear or the more structual things like pedal and hydraulics? Or can you use these from your current one?
How will you deal with the different ecu as most v6s will be automatics presumably?
DHallworth
x 167
The ECU in the link above is an ECU for a V6 manual, the same as the one fitted to the ECU, that's why both Shaun's and my own Activa V6's are currently running.
The Activa itself is already a manual and uses the same hydraulic clutch assembly as the V6 does so the master cylinder just unclips from the gearbox and clips onto the new V6 gearbox.
Did you ever manage to find out if the bell housings are the same between the TCT ML5T and the V6 ML5T, Jim?
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
x 167
Mike,
From memory the Bosch website directly that's been linked to offers free delivery whereas they're adding €17 to cover the cost of postage on that eBay advert!
I've got a list of all the parts needed and could work out the part numbers to go with it, I'll have a look at it over the holidays and see what I can knock up.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8386
David, no not had a chance yet to see if the ML5T bell housings are the same between the V6 and TCT... I they are then I'm laughing...
I need to wait until I next visit one of the other Team WFA branches
I will indeed be starting a new thread...
Very soon...
Chris570
x 36
CitroJim wrote:David, no not had a chance yet to see if the ML5T bell housings are the same between the V6 and TCT... I they are then I'm laughing...
Very soon...
They aren't.
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
