synergie diesel hard work to start - bubbles fuel line
Stewart(oily)
- x 35
Re: synergie diesel hard work to start
Cheap and easy to replace all of the leak off pipes, not forgetting the "dead end" one, there are no seals on the steel injector unions, you either have a split pipe or a loose union, dropped glow plug nuts usually end up in Narnia
Harlequin
- x 24
just a quickie - anyone know the diameter of the rubber fuel pipe from the bulb to the fuel filter?
Simon
- x 94
here is a screen shot from service citroen
https://www.dropbox.com/s/be0ya89t92jqt ... 8.png?dl=0" onclick="window.open(this.href);return false;
No. 5 and 7 are from the primmer to filter
Regards, malcolm.
Harlequin
- x 24
- x 94
Simon
No. 6 on the drawing is from the filter to the pump, and the 6mm pipe under No. 6 is for LHD only,
i thought you were asking about from the primer to the filter 5 and 7 in the drawing?????? which look like 9mm and 7mm
Regards, malcolm.
Harlequin
- x 24
sorry was at work - so the piping is 5+7+8+9 is the line from primer to filter.
ok so a 6mm inline 1 way valve wont fit as it`ll be too small?
Simon
Harlequin
- x 24
replacing leak off pipes next - 1 way valve hasn't stopped the fuel pressure and poor starting
Simon
Harlequin
- x 24
1 final bump - the air in the fuel line has reappeared - watching bubbles from filter housing through the clear pipe.
Simon
Harlequin
- x 24
Re: synergie diesel hard work to start - bubbles fuel line
any ideas? primer needs 3 or 4 squeezes to firm , then itsoftens , and I can watch bubbles in the clear fuel line from filter housing to the pump.
change filter housing? fuel line after 1 way valve?
Simon
Xantidote
- x 4
How good is the squeeze bulb itself - any signs of hardening/cracking? I seem to remember someone on forum replacing the bulb.
How flexible is the rubber hose? From experience, I had a problem with a length of the original rubber hose on my TD, between bulb & filter, albeit 1995 TD so quite elderly, which had become rather less flexible, and didn't like a change of angle where it passed through a support bracket when I'd been playing with the alternator. The net result was a crack on the inside of a preformed bend in the hose, allowing air in with suction, and squirting out when the bulb was squeezed. Easy remedy.
Are the hose clips Citroen originals, or has someone fitted a small jubilee clip somewhere in the line? I find with using jubilee clips on small diameter pipe, it's sometimes difficult achieving a good seal.
Martin
1995 Xantia TDLX (deceased
Harlequin
- x 24
replaced the fuel line from the primer bulb to the fule filter housing
replaced fuel filter housing and O ring
no bubbles in fuel line!!
still wont bloody start without easy start
Simon
- x 1502
Have you checked the valve clearances?
Harlequin
- x 24
no because theres no room to get the rocker cover off , so if it needs that then its easy start forever
Simon
Xantidote
- x 4
Well I suppose the good news is that you've got rid of the air bubbles, so that should at least have removed 1 reason for non-starting.
I was going to suggest you check the glowplugs, but I see you did that back at the beginning of the year. Might be worth checking that you've got power to the busbar, using either a multi-meter to check the voltage, or a bulb from busbar to earth. It's summer, but I'd still expect a TD to need 2-3 glowplugs to fire up, so if 1-2 glowplugs have failed in the last 6 months, you'd still get ignition with a bit of churning.
Martin
Harlequin
- x 24
